Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 03-29-2010
FirstSightPS31's Avatar
FirstSightPS31 is on a distinguished road
removing prop
This is a lot less complicated than the cutless bearing discussion.
I simply want to remove the prop from my 31--so I can take it home and paint it more easily.
However, when I removed the cotter pin, and the two nuts, it still would not come free.
I am not anxious to buy a prop-puller.
Are there any tricks to this? I am thinking of a rubber mallet as the most force I would use.
Also, when I re-tighten the nuts, is there a recommended torque?
Rod Johnson
First Sight PS31 #128
Old 03-29-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
I just bought 4 prop pullers (actually gear pullers) on eBay for IIRC $20 plus shipping. Why not just get one and re-sell it when you don't need it?
6"Gear Puller - 3 Jaw - Heavy Duty : eBay Motors (item 360242327614 end time Apr-04-10 18:00:00 PDT)
I think you may need a 2-jaw puller if you have a 2-blade prop. I haven't used mine yet for prop pulling yet.
Regards,
Brad
Old 03-29-2010
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Yes. The trick is to use the right tool for the job. You need a prop puller.
"Clean bottoms are FastBottoms"
Old 03-29-2010
The prop sits very close to the rudder (skeg hung) so I am not sure there is room for the gear puller. Nice suggestion though.
Rod Johnson
Old 03-29-2010
Fstbttms's Avatar
Another reason to use a prop puller. It is unlikely that you will be able to remove the prop otherwise.
Old 03-29-2010
JohnRPollard's Avatar
Moderator
Hi,
Haven't had to pull ours yet, so can't offer a suggestion. My only thought is, given the difficulty you're having with removing the prop, why not just paint it in place?
It only takes a couple minutes to spray the entire prop with the Pettit zinc barnacle buster prop paint. It dries quickly, too, so you can get a few coats on in relatively short time period.
Just a thought. Anyway, let us know how it goes.
Old 03-29-2010
Maine Sail's Avatar
Don't know about the PSC 31 but many apertures open up when the rudder is swung full over, at least enough to get a gear puller in there.
With a properly installed prop you will NOT get it off with a hammer and will only damage the prop trying. Trust me it takes a lot of ft pounds of torque even with a gear puller before it finally goes POP! Always leave a nut on loosely when using a prop puller or it will go flying right off the shaft..
______
-Maine Sail / CS-36T
Old 03-29-2010
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Hmmm, my maxprop hub came off pretty easily this winter.
PYI suggested I use anti-sieze when I put it back on...
Old 03-29-2010
Maine Sail's Avatar
Very scary!!!!
______
Old 03-29-2010
Very scary!!!!
What?
That I have a maxprop?
That it came off easy?
That they recommend anti-seize?
That I can't find my setscrews?
That I know how to spell?
Don't leave me hanging like this!
HTML code is Off
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
3-blade fixed prop recommendations? KeelHaulin Gear & Maintenance 15 05-18-2010 01:03 PM
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 2 11-28-2009 02:19 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
