04-21-2010
I just received my PSS shaft seal and have been reviewing the installation instructions.
Step 15 plumbing the system:
note: sailboats or displacement powerboats with powering speeds below 12 knots can use either method A or B. However, displacement boats with a bearing in the shaft log must plumb water to the seal
Pacific Seacrafts have a bearing in the shaft log. Water must be plumbed to the seal according to the instructions. If there is no bearing in the shaft log then all that is needed is a vent hose above the waterline.
What method was used in the boats that have a PSS shaft seal with a bearing in the shaft log??
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
