04-30-2010
Originally Posted by elliottrt
Hi All,
I recently had the mast removed on my 1989 34' Pacific Seacraft, to fix a leak. To keep water from entering the hole where the mast wires run through the cabin top, a piece of radiator hose had been glued to the aluminum base the mast sits on. The radiator hose had deteriorated to the point that water was seeping under it. Easy fix. However, inspecting the hole that runs through the cabin top, I see something that looks all wrong. At the base of the mast, the cabin top has been built up about an inch higher than the rest of the cabin top. This provides a level surface, and I assumed it added extra strength to the cabin top to take the load of the mast. Peering down the hole past the aluminum mast step and stainless steel plate, I expected to see solid fiberglass and plywood all the way to the compression post. Instead, I see a layer of fiberglass (the built up area) , followed by an air gap about 3/8'' deep, and then the fiberglass-plywood-fiberglass layer that the rest of the cabin top consist of. My first thought was that there use to be plywood where this air gap is, and that it rotted away. However, it is too clean. It does not appear that anything was ever in this space. I can take a coat hanger wire and probe this space, and it appears to go about 2 or 3 inches horizontally around the hole. I assume that where the bolts for the mast step and stainless steel plate go through the deck, that it is solid (no gap), but without removing them, I cannot tell. Has anyone else seen anything similar to this. I can't decide if this gap is per design, or if I should be figuring out a way to inject fiberglass resin or marine tex in this space.
Thanks,
Richard Elliott
Nepenthe
Lake Texoma, TX
Richard
Why don't you call the PSC Factory and ask them? And if they recommend that you fill that void, being on Lake Texoma - you are not too far from the shipwrights at Valiant yachts - I'm sure they could fix her up.
Regards,
Ted
V42#186
s/v Little Wing
