Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #11 (permalink)
Old 05-13-2010
stevemac00 is on a distinguished road
Sorry for the multiple posts. I removed the space to see if that fixed it.
http://sail-talisman.com/talisman/psc/Rigging_Guide.pdf
Steve
PSC 31 #84
Talisman
  #12 (permalink)
Old 05-16-2010
BirdBrain333 is on a distinguished road
Reefing lines
Dear Steve,
Thank you so much for posting your PSC rigging guide. On the PSC 37 the lines are led to cheek blocks about 8" aft of the respective reefing cringles. The problem then is that the furled portion of the sail forces the reefing line out against the cheek of the cheek block, increasing the friction exponentially. It was basically useless. Based on your drawings I removed the cheek blocks and moved them aft of the outhaul at its furthest aft position. The lines now lead perfectly!
Also, I discovered that the electrolosys between the stainless cheek block and the aluminum boom had eaten a spot about the size of a dime about half way through the boom! Needless to say when I re-mounted them I isolated them with a layer of plastic between the block and the boom and used LOTS of Lanocote on the rivets. Others may want to inspect for telltale white dust.....
Thanks again, we launch next week and I'll let everyone know how the new lines work out.
Jay
PSC 37 # 171, Kenlanu
  #13 (permalink)
Old 05-17-2010
Last year I bought a new mast from LeFiell and they said to coat all stainless steel with Tef-Gel. Tef-Gel viscosity makes it easy to apply.
Steve
PSC 31 #84
Talisman
  #14 (permalink)
Old 05-17-2010
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
The Orion has the first reef coming out of the stbd end sheave and the second reef going to a cheek block. The port end sheave was for topping lift. I changed the topping lift config (which frees up the port boom end sheave) and now run both reefs from the boom end, tying off to boom with bowline on a bight slightly aft of each respective reef clew. This new to me config (just like in the 31 rigging guide) provides a really nice sail shape.
Dictated, but not read.
HTML code is Off
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 07:00 PM
Setting Up Reefing Tackle Dan Dickison Learning to Sail Articles 0 12-13-2000 07:00 PM
