Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #21 (permalink)
Old 12-30-2010
Large Member
mdbee is on a distinguished road
Clamps
Iv'e built several of these panels for myself and others. These are smaller 20watt models, so only one clamp was needed.
I used clamps for the Magna grills:
MAGMA PRODUCTS | DUAL RAIL Mount 1" | T10580 from the ShipStore.com ™ on-line catalog.
We've just installed panels on the Womboat but I'm not impressed with the rail clamps.
Norstar .. where did those clamps you've used come from ?
tdw
  #22 (permalink)
Old 12-30-2010
night0wl's Avatar
night0wl is on a distinguished road
Using magma grill mount clamps...BRILLIANT!!!
Why didn't I think of that!
S/V Jendai
Beneteau 343
  #23 (permalink)
Old 01-01-2011
Norstar's Avatar
Coastal Carolinas
Norstar is on a distinguished road
Steve, No big deal to take the canvas bimini and dodger off for storm prep. We leave the frame up.
TDW, Hardware clamps were all supplied from E-Marine as a kit. I believe they have them available for individual purchase.
John S
PSC 34 #201
Norstar
  #24 (permalink)
Old 04-08-2011
matt195583's Avatar
matt195583 is on a distinguished road
I know this thread is old but I am looking at mounting panels above my bimini also ... the magma grill clamps are about $80 odd here. so that rules them out. What I was thinking is hydraulic pipe clamps ... has anyone used these ?
SV Blue Print
Brisbane AU
  #25 (permalink)
Old 04-08-2011
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
Originally Posted by matt195583 View Post
the magma grill clamps are about $80 odd here. so that rules them out. ?
Nylon blocks drilled for 1 inch rail the cut length-wise and drilled for bolts.
Need a shop doing that sort of fabrication. Simple quick job so shouldn't cost much.
You might be able to find a kitchen cutting board thick enough to do it, and make the holes yourself.
Sea Life
Notes on a Circumnavigation:
  #26 (permalink)
Old 04-08-2011
erps's Avatar
the pointy end is the bow
That's what I did, only I used Trex deck like board material. It comes in a couple colors. I'm still evaluating whether it was a good choice over the long haul, but so far, so good. It's cheap enough, that I don't mind a little trial and error.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #27 (permalink)
Old 04-08-2011
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
We ended up using the Magma clamps but .. The cheap rail clamps we bought from Whitworths
are quite adequate for holding the panels in place but they don't have the strength to stop the panels from moving. We have two panels mounted on twin rails over the bimini so eight clamps. Four of these are the cheapies, the other four Magma. in the light of day it is apparent that we could have gone with six of the cheapies and just two of the Magma as a final clampdown. Thus far it all seems to work well. If we want to change angle of the panels we can loosen the Magmas as required.
Ultimately the size of panels will determine how much 'clamp' you need. We have two by 80w.
That said our problem now is that the our bimini frame mounts onto the pushpit, it is not anchored to the deck. With the panels up top it now has a bit of sideways movement. I seriously doubt it will fail, but the 'wobble' is a bit off putting.Somehow I am going to need to add a couple more uprights anchored down to the deck or perhaps simply a couple of horizontal angled bars.
We still need to tidy up the wiring and have the new canvas refitted but I'll post some pics when complete.
  #28 (permalink)
Old 04-08-2011
erps's Avatar
If you drink enough and wobble at the same frequency, it may become less off putting?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
HTML code is Off
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 07:00 PM
