Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-17-2010
HankJordan is on a distinguished road
34 bilge pump
Greetings all,
My current rule bilge pump with separate float swicth set up is not removing all of the water. This may have been the case all along ... but I am just now noticing.
Whenever I run the electric pump manually with the three way switch it pumps the bilge dry but once I release the switch about two cups or so of water run back down the hose in to the bilge.
Is this normal?
Solutions?
What should I be checking for problems?
Thanks.
Crealock 34, #68, s/v Lou Ann
Old 06-17-2010
teejayevans's Avatar
teejayevans is on a distinguished road
Originally Posted by HankJordan View Post
Greetings all,
Is this normal?
Solutions?
Thanks.
yes, because the water left in the hose returns, the only solution is
to prevent water coming in.
Tom
PS31#111 Cielo Azul
Old 06-18-2010
RainDog's Avatar
Not Finished Yet
RainDog is on a distinguished road
As Tom points out it is the water in the hose. You can reduce the volume by replacing the hose with a thinner diameter hose.
A one inch ID hose will hold 1 cup every 18 inches.
A .75 inch ID hose will hold 1 cup every 32 inches.
A .5 inch ID hose will hold 1 cup every 73 inches.
A .25 inch ID hose will hold 1 cup every 294 inches.
This of course reduces the max capacity of your bilge pump. The default install on my boat was a single hose with a .75 or 1 inch diameter (don't remember). I am replacing this with the system recommended by Don Casey: Installing a Bilge Pump by Don Casey
"The ideal bilge pump arrangement is a small (400 gph) automatic bilge pump mounted in the sump to dispense with rain and shaft-gland leakage, combined with a high capacity pump (3,500 gph) mounted higher to deal with more serious ingress.
Stepping the discharge hose from the small pump down to 1/2-inch minimizes the backflow from the hose when the pump cycles, maintaining a dryer bilge... the high-capacity pump sits high and dry, extending its life indefinitely."
Pacific Seacraft 34 #142
Seabrook, Texas
Old 06-18-2010
wmjr is on a distinguished road
bilge water
My current solution is a turkey baster and a water bottle or two (little 10 oz size) for a normal sail of one hour motoring and 2 or 3 sailing.
On a longer trip with lots of motoring I get the pump out of the dock box when I get back.
The constant washing keeps the bilge clean (Yeah, I know, it wouldn't be dirty if I switched to a dripless.)
I really like the Don Casey two pump idea but the turkey baster is too easy to get me working on it.
John Van Dinther
PSC 31 #28
Old 06-19-2010
stevemac00 is on a distinguished road
I agree this is a nuisance. I always wondered why you just can't put a check valve in the hose. There must be some important rationale I can't think of so I just suck it up with a little hand pump then wipe dry.
Steve
PSC 31 #84
Talisman
Old 06-19-2010
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by stevemac00 View Post
I agree this is a nuisance. I always wondered why you just can't put a check valve in the hose. There must be some important rationale I can't think of ...
The concern is the check valve will stick closed.
Jim
s/v Abracadabra
1976 Pearson P30
Old 06-19-2010
Jim
Not to mention you don't want any resistance for max output flow rate
Tom
PS31#111 Cielo Azul
HTML code is Off
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
