04-17-2012
Re: Swaged fittings vs. mechanical fittings
A note in passing, Don Street's "Cruising Yacht" books, published in the 70s? 80s? devoted some attention to swages versus mecahnical fasteners, and most of what is on the market today, was already available back then. These things have been in use for decades, and they have a proven history.
What it all comes back to is that "patent" fittings cost more bucks per each fitting. But swages require a large and expensive tool to be properly made. So if you need to take spares with you--the patent fittings are going to be cheaper. If your rigging is going to be fitted professionally where the roll swage equipment already lives...no brainer, they're cheaper and equally effective.
One is better suited for production work in a yard, the other better for carrying spares to use at sea. Properly installed, from a reputable source, both work just fine.
