Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-29-2010
discoverer37 is on a distinguished road
Prop zinc for ps37
Does anyone know what is the correct prop nut zinc for the PS37?
I'm not near the boat and was hoping to get one before I return, but I'm confused. I have the original, standard fixed three blade prop, and the dimensions on the Martyr web site would suggest the correct size is CMPN-C
But, I have one of those, and I thought I tried it and it was too big.
Thanks,
Paul Hill
PS37 #135
Old 06-29-2010
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Prop zinc size is determined by shaft diameter. The correct zinc for a 1" shaft is the "C" size. If you are positive that the "C" zinc does not fit on your prop nut, either you do not have a 1" shaft or some other change has been made that requires a different prop nut.
"Clean bottoms are FastBottoms"
HTML code is Off
Broken prop shaft - saved by the zinc harbin2 Gear & Maintenance 14 05-31-2010 08:24 AM
How to attach Prop Nut Zinc? preservedkillick Gear & Maintenance 6 05-15-2010 12:23 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
