07-12-2010
I had a 12000 btu split unit. The compressor was portside aft in the lazarette, the rest of the unit in the wet locker. A shelf in the wet locker over the evaporator unit salvaged the rest of the space in the locker for use. Return air and controls were in the aft bunk. Ducting was led through the bottom compartment of the head cabinetry, across the bottom of the hanging locker, then up the forward side of the locker with vents over the chart table and in the forward bulkehead of the head. Condensate drained into the bilge. All of this had its ups and downs.
Pros: Noise. Compressor was entirely inaudible in the cabin and cockpit. Exhaust water was under the counter (overhang) which was entirely quiet as opposed to the way most boats just piss the water straight out the side. The noise in the wet locker was minimal, just the fan, and that was inaudible in the cabin. All you could really hear was the rush of air out the vents and an almost subliminal 60hz hum. Continuous trickle of fresh water into the bilge seemed to keep smells and such under control.
Cons: Too many bends in the ducting. That cut down on efficiency of the unit. An 8000btu window unit in the companionway actually seems more comfortable, though pretty noisy.
All of this was in Houston TX and Tampa FL, temps in mid-90s and humidity as high as it gets.
