Prop Size for Crealock 37 w Yanmar 4JHE - SailNet Community
post #1 of 1 Old 07-19-2010 Thread Starter
A couple of years ago I had to re-power Crazy Fish and replaced the Yanmar 4JHE that was originally installed on the boat in 89 with a new Yanmar 4JH4E.
The old engine generated 44 HP max and the new one generates 55 HP max. The factory currently is installing a 39 HP engine.
The boat is currently under-proped with its 3 bladed prop. I was wondering if anyone knows what the proper sized 3 bladed prop would be ?
And the boat needed to be re-powered when Baja Naval in Ensenada reinstalled the transmission (which had frozen) with the powerplate backwards. The engine ran but it put a lot of pressure on the engine bearings and after about 12 hours of total runtime the bearings seized.
Thanks
Marc Hall
Crazy Fish, Crealock 37 Hull 207
MarcHall is offline
Fuse size for a Yanmar 2GM20F Dave D Electrical Systems 2 07-15-2010 10:36 AM
Prop Size for Perkins 4-108 KeelHaulin Gear & Maintenance 6 11-22-2009 03:58 AM
Good Prop Size for Express 30 wstewart Announcements and Suggestions Box 1 02-10-2007 01:38 PM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
HTML code is Off
