10-25-2010
Bob,
It's a KCM85 Kyocera panel. I bought the stanchion mount kit which includes the solar panel, mounting hardware, charge controller, remote display and plenty of marine grade (tinned) wire from e-marine on the net. I cut the stainless tube that came with the mount kit in half and bought a couple more rail clamps at the local chandlery. I fitted the two short tubes along the width of the panel instead of the length as the kit was originally intended. I mounted the four rail clamps to the teak frame of the hatch cover, then mounted the two tubes and panel to them. It's really solid, but the whole lash up can be removed in 10 minutes.
As I recall, I had e-marine upgrade the controller in the kit to the one with the battery temperature sensor. This turned out to be a really good idea. The AGM's are in really good shape after three years.
The panel has taken a lot of wind, salt water and raw tropical sun, and it's still in terrific shape. The anodized frame is still in like new condition. We have been really impressed. I think Kyocera has a 20 year warranty on them. Good luck. Let me know if you need more detail.
Dave Mancini
PS34 #305 "Swan"
