Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 09-08-2010
jkfink is on a distinguished road
Bow roller-anchor attachments
I recently purchased a 1988 PS37. I have 35 lb Delta and 45 lb CQR on dual bow roller. Holes for retaining pins do not align with bow roller holes (and the use of horizontal retaining pins has been discouraged because they could become bent and stuck by anchor movement in a seaway).
Question: How have others secured similar anchors to bow rollers/fore decks?
Old 09-08-2010
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
Lash them down.
Rick I
Toronto in summer, Bahamas in winter.
Old 09-08-2010
JohnRPollard's Avatar
Moderator
Hi jkf, Welcome to Sailnet!
On our 31, we have two short, coated-wire pendants that are secured to the lower rail in the bow pulpit on one end, and have a shackle in the other end. The shackle is secured through the hole in the crown of the anchor (the one for the trip line/anchor buoy.)
Old 09-08-2010
wsmurdoch is on a distinguished road
Take a look at the 02/24/2009 thread "Ground Tackle Upgrade".
Bill Murdoch
Old 09-09-2010
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Arrow
Anchor retainment (Rocna Knowledge Base)
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 09-09-2010
SVArgo's Avatar
S/V Argo-Pacific Seacraft
SVArgo is on a distinguished road
Large Pin Loading
We have pins, and like them. I couldn't find the ground tackle thread, but read Rockna's recommendations, and have to believe that it may be more in the design and arrangement of the pin securing mechanism than a general pin concept in and of itself.
A quick deflection analysis of our pin arrangement, 0.375" dia SS pin on 6" supports with the anchor more or less in the middle, would require the equivalent head of ~20 ft of water to produce a 0.25" deflection in the pin. Based on that, it looks like, while possible, it's in the statistical tail that you'd hit a wave hard enough to bend the pin to the point that it can't be removed, if it is designed properly.
Of course, poorly designed and built stuff breaks all the time.
We've hit some hard waves, big steep ones that roll over the dodger, and have never had any deflection serious enough to jam it. And as far as the Rocna's website suggestion that it be lashed goes, if the seas are heavy and consistent enough to bend a 1/4"-3/8" stainless steel rod, it is reasonable to believe it's enough to chafe through any fiber lashing at the bow.
All that said, a proper bowsprit/pulpit and roller arrangement that allows the flukes to ride under the roller, should prevent most vertical translation when coupled with a tight chain stopper, devil's claw, snubber, etc.
I do like the wire rope and shackle idea for where the pins and pin brackets don't meet and think I'll use it until I can get someone to TIG some new SS brackets on for the Bruce.
Ryan
Ryan Roberts
S/V ARGO - Pacific Seacraft 37 Hull No. 309
Old 09-09-2010
Let's see if this link to the older thread works
http://www.sailnet.com/forums/pacifi...e-upgrade.html
Bill Murdoch
Old 09-20-2010
securing bow anchors
Thanks to everyone for their input. Wire pennants from the bow pulpit rail may be easiest. This would prevent primarily forward/downward movement of the anchor (ie. self deployment). I would still need to tie down the anchor shank to prevent it from bashing against the foredeck. (In contrast, a pin, through the anchor shank could lift it above the foredeck and prevent essentially any movement).
Ryan (SV Argo), do you have photos of your set up?
John
Old 09-20-2010
SVArgo's Avatar
John,
I don't have any photos of our setup, but if I have a chance this week, I will take a couple.
Ryan
Ryan Roberts
Old 09-21-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Depending upon where the shank of your anchor rests on deck, you might be able to use these: Anchor Lock
HTML code is Off
Anchor roller nikonf3blue CS Yachts 1 04-02-2010 07:45 AM
Anchor roller Thor5101 Gear & Maintenance 5 06-08-2009 02:23 PM
Anchor Roller on bow cygnetOH Newport 5 12-23-2007 12:18 PM
anchor roller ThomasTralee Gear & Maintenance 1 04-16-2003 01:19 AM
anchor roller jimdafoe Gear & Maintenance 0 02-15-2002 05:52 PM
