09-17-2010
Not So Senior Member
PSC water tanks are built into the liner and are gelcoated. That may be leeching, could be old plumbing too??? i have an Orion, not a 37 but the water tanks are similar.
When you get in there you'll find some plastic thru hulls penetrating the tank (one vent, one bigger fill, and a supply to the water system). Not much else in there.
the water tank under the quartberth may have a support that is molded into the tank somewhere in the middle so when you lay on the quarter berth it doesn't stress the tank lid (mine does).
I installed watertight clear screw down deck plates in my tank lids for easy inspection and cleaning. Might want to concider it when you get into your tanks.
Dictated, but not read.
