Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 09-21-2010
sachemgfp is on a distinguished road
Diesel Air Intake
Remembering that air is a primary mixture for diesel operation, has anyone noticed that there is no ducting of air to the engine on the 37's? I have had no problems with engine performance just wondering where the fresh air was coming into the engine compartment.
Thanks George
S/V SACHEM # 335
Old 09-21-2010
teejayevans's Avatar
teejayevans is on a distinguished road
Thanks George
S/V SACHEM # 335
31's have ducting to engine compartment, so it must be a model
dependent thing.
Tom
PS31#111 Cielo Azul
Old 09-21-2010
MC1 MC1 is offline
MC1 is on a distinguished road
On the PSC '34, we can flip open the little engine compartment lid, just under the companionway ladder. From pictures I have of the '37, it looks like you should be able to do the same if you'd like to give your engine a little more air to breath. If you're pushing the engine hard and/or it's particularly hot, it might be worth doing.
Old 09-21-2010
arisatx's Avatar
arisatx is on a distinguished road
Thanks George
S/V SACHEM # 335
George:
We had vents on the upper surface of our stbd coaming box, if I recall correctly.
Regards,
Ted
V42#186
s/v Little Wing
Old 09-22-2010
Diesel Air Intake
Thanks Ted,
Now that you mention it I do recall the vent in the stbd coaming box.
George
Old 09-23-2010
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
On another subject I was looking at a 1994 PSC 34 that appears to be in mint condition except the engine, 44JH2E, has 4195 hours on it. Any comments? The Dealer says the owner has records of engine maintenance done.
Old 09-23-2010
As part of the standard boat inspection I would have a mechanic check it out (check compression, etc). General rule is that a well maintained diesel engine can go 8000 hours without a major overhaul.
Tom
PS31#111 Cielo Azul
HTML code is Off
Diesel intake air, noise and filter deniseO30 Gear & Maintenance 6 08-18-2011 09:27 AM
Air intake on Westerbeke 13? Tanley Diesel Engine Forum 2 05-28-2010 06:36 AM
Raw Intake Screen Stu01 Gear & Maintenance 6 10-08-2008 12:43 PM
raw water intake rchad Gear & Maintenance 12 06-26-2008 08:19 AM
Head Water Intake maddata Gear & Maintenance 1 06-19-2007 07:13 AM
