Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 09-23-2010
pc237
pc37howard is on a distinguished road
Cool stay sail quick release
could any of you pacific seacraft owners help me with a ? what do you think of a quick release for the inner jib stay, or to some the forstay. thanks for any help
Old 09-23-2010
teejayevans's Avatar
teejayevans is on a distinguished road
I have (ABI?) quick release on inner stay, when river sailing, I go into sloop mode, best of both worlds.
Tom
PS31#111 Cielo Azul
Old 09-23-2010
knothead's Avatar
I was looking for a quick release lever recently and discovered that ABI no longer makes them. CSJ makes them but only small ones with a 1/4" pin.
What I did was use a double toggle turnbuckle with a fast pin on a lanyard for the top. To remove the stay, you can take a few turns off the turnbuckle, pull the fast pin and then take the stay aft to the rail and it will be short enough to not drag on the deck. You can leave the turnbuckle on the foredeck if it's secured with a bungee or cord. The marine eye on the end of the wire can be secured to the rail with a shackle on a strong bungee as well.
Ron Paul 2012
"wikijar"
Old 09-24-2010
JohnRPollard's Avatar
Moderator
Knotty,
That sounds clever. Got any photos?
I was surprised that ABI's was no longer available, but poking around I found this which confirms:
Staysail Release Levers | Sailing Blog | Lin & Larry Pardey
Old 09-24-2010
knothead's Avatar
Originally Posted by JohnRPollard View Post
Knotty,
I didn't take any pictures of the set up before the boat left, but it's pretty simple.
Take one of these.
use one of these with a short lanyard made of 1/16" vinyl coated wire attached to the t-bolt (to keep from losing it) for the top
It's better if the fast pin is extra long to give you something to hold onto for tightening and loosening.
Swage a marine eye or attach one of these to the end of the wire
and there you have it.
Ron Paul 2012
"wikijar"
Old 09-24-2010
FirstSightPS31's Avatar
FirstSightPS31 is on a distinguished road
inner forestay
My rigger shortened the inner forestay and added a Wichard "adjuster". I used the one with a pump handle rather than the roller, to save expense.
He also shorened the stay further and created a removable flat stainless steel extension (about a foot long), so that the stay can be clipped to the aluminum toe rail with no slack.
He was opposed to one of those coach roof mounted tracks to bent the stay and take up the slack.
To deploy, I attach the metal bar to the deck, and the end of the adjuster to the metal bar; the handle is then used to adjust the tension of stay.
I would add that this is a very expensive solution to the problem. I am not necessarily advocating this approach as superior to any of the others that have been mentioned.
Rod Johnson
First Sight PS31 #128
Old 09-24-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Or just use dyneema and a lashing.
Merit 25 # 764 "Audrey"
Old 09-24-2010
niftynickers is on a distinguished road
inner forestay quick release
Check out Johnson Marine Hardware pgs 33-34.
I think you will find what you are looking for.
Ive had a Johnson handle for years on my C37.
Dianne and Chuck Burke S/V NiftyNickers C37 #139
Old 10-01-2010
BMLipiec's Avatar
BMLipiec is on a distinguished road
Last year at the Annapolis Boat Show, the PSC 34 on display had a removable staysail stay. In addition to the quick release mechanism, I really liked how they stowed the stay. It's hard to see in the pictures, but the stay ran through a small cradle attached to the mast pulpit bar and then clipped onto it's own deck fitting. It kept the stay secure, mostly out of the way and prevented kinking.
stay sail quick release-img_2354-800x600-640x480-500x375-.jpg   stay sail quick release-img_2357-800x600-640x480-500x375-.jpg
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
Old 10-12-2010
melydiae is on a distinguished road
Thumbs up stay sail quick release
As the owner of Anam Cara, I would like to add that this modification has worked extremely well. We usually sail her as a sloop but the staysail is up in minutes. We were amazed at how Steve Brodie and his team were able to find solutions to make this the perfect cruiser for us.
HTML code is Off
Need sources for staysail stay release lever Lin and Larry Gear & Maintenance 9 03-17-2010 11:05 PM
Stay sail Boom wookie General Discussion (sailing related) 3 12-08-2009 11:48 AM
Quick Release - Snap Shackles Reddirt General Discussion (sailing related) 4 10-12-2009 04:08 PM
Opinion on Wichard Quick Release Shackle? labatt Gear & Maintenance 3 07-16-2007 12:25 PM
Quick turn around for B & Q @ Sail World UK NewsReader News Feeds 0 04-20-2006 07:15 PM
