01-05-2011
Removing carpet "ceiling"
Dear Erica, On our Pacific Seacraft 37 that carpet was REALLY glued on. I first took down the overhead which allowed me to get to the very top edge of the carpet where there was about 1/2" to 1" of carpet without glue. I used an old crochet hook to "grab" the top edge of the carpet and pull it down to where I could get a pair of vice-grips firmly clamped on and then started pulling. After about 20 min of bracing my feet on the bulkheads and pulling, yanking, and uttering things I care not to repeat here, I realized a different approach was needed. So out came the Fein Multimaster with its scraper blade. I also had an old, very dull, metal cutting saw blade with, after cutting off some stubborn stainless bolts, has only nubbins of teeth left. Still with vicegrips to help pulling, I simply "sheared" the monkey fur off the hull with the multimaster. It was MUCH easier but still enough labor to work up a sweat in 35F temps. Then out came the Makita right angle grinder to take off what I could of the quite tenacious glue. This, I"m sorry to report, put a nice layer of sticky "dust" throughout most of the boat! There must be a better way to get the glue off but I sure don't know it.
I'll attache two pictures, one of the "shearing" and the other demonstrating the joys of grinding......
So which boat is getting the makeover? Hope this helps,
Jay
PSC 37 # 171, Kenlanu
