11-20-2010
You'd be far better off, and 'shippier' looking with a planked ceiling. Not difficult to do although the PSC may have more compound curves that other racier shapes. Carpet - IMO - has no place anywhere on a boat, esp glued in place.
Strip it off, and epoxy some vertical furring to the hull - about 15 - 18 inches apart, about 3/4 thick. You may need to kerf-cut the piece to get it to conform to the curves. Fill the spaces between with some closed cell foam (a hiker's sleeping pad, or other source sometimes called 'ensolite'. Then plank the ceiling with some 1 1/2 or 2 x 1/4 or 3/8 battens. Cedar is lightweight and looks great, but pricey and may be hard to find, but any clear lumber will do; you can always stain and finish to close to a match with your bulkheads if you wish. It will take some triming to fit the boards at the extremes of curvature, but often you can 'hide' the odd ends below the cushion level.
An alternative to wood furring strips is to lay on some bent tubing with straps of fg matte, predrill for screws and carry on the same.
This process is well illustrated in Bruce Bingham's "Sailor's Sketch book".
And from "This Old Boat":
This Old Boat - Google Books
You will really like the result!
1984 Fast/Nicholson 345
