Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 11-25-2010
andantesail is on a distinguished road
Mark 2 Wheel Pilot Issue
My Mark 2 wheel pilot clutch slips out of gear under way, not convenient, and I can't figure out how to fix it. I've taken to tying it up with a small cord, but that's hard to undo in the dark etc. Any ideas?
Thanks
Karl
Andante PSC 34 #276
Karl
"Andante" PSC 34 #276
Old 11-25-2010
therapy23's Avatar
Back to just the Jon boat
therapy23 is on a distinguished road
Are you talking about the little locking lever that you push down/rotate to engage it?
Is it popping up?
First check to see if the lever screw is loose.
Page 7.
Part #6 (two of them)
Not that?
There is a little black knob next to where the motor is inserted into wheel drive. There is a set screw in the center of it. Loosen the set screw a turn or so and screw the knob in two or three clicks. Re-tighten the set screw. It usually is not much of an adjustment. Don't make it too tight.
Page 10
This is what I did to solve my problem. First it was too tight and then too loose. Now it is just right.
http://www.raymarine.com/submittedfi...2_wheel_sm.pdf
Old 11-25-2010
Thanks, I did two out of three. I'll retry.
Karl
Karl
Old 12-05-2010
samchristo is on a distinguished road
Our old wheel pilot (which finally failed in the Gulf of Mexico) would slip out of gear at the most frustrating moments. We finally fabricated a small noose from shock cord to hold it in place. It was quick and easy to slip on and off and served for a good many years before the drive packed it in.
Sam
s/v Grace PSC34
Old 12-05-2010
Sam, yes I tie mine up also, just a pain. Hoped for a fix. Good to know I'm not the only one
Karl
Old 12-12-2010
Wing n' Wing
Lansdowne is on a distinguished road
We do the shock cord also, but we have found that rinsing the drive belt with fresh water after a trip helps a lot.
HTML code is Off
Smart Pilot Raymarine X5 Wheel Pilot chef2sail Gear & Maintenance 35 07-07-2011 02:29 PM
Raymarine Mark 2 wheel pilot slippage andantesail Pacific Seacraft 2 04-04-2010 07:45 AM
wheel pilot differences dvpamenter Gear & Maintenance 2 03-05-2009 11:31 PM
RAYMARINE S1 Wheel Pilot Freesail99 Gear & Maintenance 4 07-23-2008 06:04 PM
Navico wheel pilot dvpamenter Gear & Maintenance 4 01-22-2007 12:00 PM
