02-17-2011
I'd never disagree with those who say their pump is before their Racor. If it is, it is. I merely note that my 31's manual says the same thing and regular visual inspections for leaks and such never caused me to doubt it. I'd have bet several boatbucks on it.
But when I actually had to work on my fuel system, I found something different. My fuel line runs from the tank, behind the pump, to and thru the Racor, back behind the Racor and the pump, thru the pump, behind the Racor, and finally to the engine. Yes, there are 2 180 degree turns in the fuel lines. This sounds crazy, but it is so. Given the relative sizes of the Walbro and the Racor and the layout of the area, it even makes sense.
Again, I'm not telling anyone this is how their boat is set up. But I doubt that many people would have deduced the actual setup on my boat without actually removing and tracing fuel lines. Your mileage may - and probably does - vary.
I'm just sayin'.
Wiley
