Singlehanding a PSC37??? - Page 6 - SailNet Community
 1Likes
post #51 of 52 Old 09-17-2012
Re: Singlehanding a PSC37???
Seacurves,
here's an idea that works for me.
Goal: hoist main at mast, but be able to drop main from cockpit.
Solution:
1. I tie a snatch block to aft rail (stern pulpit) and lead it just aft of main halyard line-clutch (anywhere in cockpit is fine, as long as it is lead fair from halyard line clutch).
2. Mainsail halyard bitter end goes through its line clutch, then through the snatch block, then returns to mast (not necessary to run it back to mast through deck organizers etc).
3. Keeping the halyard line clutch in the closed position (preventing sail from dropping), I hoist main halyard at the mast, alternating with pulling up the slack on main halyard bitter end (that has returned to mast from snatch block).
4. When sail is essentially hoisted at mast, return to cockpit, remove halyard bitter end from snatch block, and finish hoisting halyard with winch.
John
jkfink is offline
post #52 of 52 Old 09-18-2012
bill norrie
our PSC 37 Terrwyn also loves her "Strong Tack" and single line reefing so we can reef at most wind angles solo from the cockpit not a problem even in the night and blowing.
Bill
BillNorrie is offline
Batteries in a PSC37 johnbanfield Pacific Seacraft 1 01-13-2011 05:04 PM
Access to behind the engine of a PSC37 johnbanfield Pacific Seacraft 15 01-20-2010 06:20 PM
Alternator upgrade on PSC37 with 5432 discoverer37 Pacific Seacraft 1 10-18-2008 04:08 PM
Spray Dodgers on a PSC37 - Inspiration arisatx Pacific Seacraft 9 06-10-2008 09:38 PM
Autopilot for PSC37 gpeacock Pacific Seacraft 3 01-17-2007 09:33 PM
HTML code is Off
