Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 04-10-2011
barkmecrazy is on a distinguished road
reacher tack
Hi PS owners (or not),
I'm still getting to know our Pacific Seacraft 37. I have a question about the reacher tack. It's not obvious to me where to attach the reacher's tack shackle. I've attached it to the anchor roller bar, both from outside the bow pulpit and from inside, but then the tack pennant leans on the pulpit - not ideal. I don't see any better place to attach the tack. Does anybody have a suggestion on the best place to attach the reacher tack or how to create a good attachment point?
Thank you!
Old 04-10-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
If set inside the bow pulpit, consider using a set a parrel beads (or an ATN "Tacker") passed around your headsail to hold your tack on the centerline of the yacht. Personally, I prefer to use a snatch block attached to the cross pin in our starboard bow roller and use a line passed through that to the tack, outside the pulpit, that allows me to adjust the height of the tack when bearing away. (See Asymmetrical Spinnaker The tack arrangement can also be used with a light weight drifter/reacher)
FWIW...
Old 04-10-2011
Thanks, HyLyte. Will try the snapshackle idea as I, too, would like to control the height of the tack.
HTML code is Off
Gennaker/reacher Dcneuro General Discussion (sailing related) 3 06-09-2009 12:50 PM
reacher (drifter) mac 26m vichult MacGregor 1 09-25-2008 11:13 AM
Reacher vs Drifter terryjoe Gear & Maintenance 8 07-11-2008 10:06 AM
jib and reacher design stm Sailboat Design and Construction 15 01-06-2008 06:28 PM
reacher or runner? Zogumwesterly Gear & Maintenance 3 08-13-2007 11:29 PM
