-   Pacific Seacraft (http://www.sailnet.com/forums/pacific-seacraft/)
-   -   HIN location (http://www.sailnet.com/forums/pacific-seacraft/73554-hin-location.html)
brokesailor 04-11-2011 08:06 AM
HIN location
I got my Md title back from DNR and even though the HIN on the application started with PCS the title came back PSC and then the number. Which one is correct, I'm away from the boat right now. Alsoo where is the HIN normally located on the Crealock 37?
jackdale 04-11-2011 10:55 AM
Not sure about the PCS / PSC issue.
The boat manufacturer must display two identical hull identification numbers, no less than one-fourth of an inch high, on each boat hull. The primary HIN must be permanently affixed (so that it can be seen from outside the boat) to the starboard side of the transom within two inches of the top of the transom, gunwale, or hull/deck joint, whichever is lowest.
ralopata 04-11-2011 11:32 AM
I believe PCS is correct. Our HIN also is a PCS number, and Maryland DNR used PCS on ours (and the Coast Guard also used PCS on the documentation...).
Perhaps somebody's fingers slipped inputting your data at DNR.
Roger Lopata
JUNO
PSC 40 -- #46 (or should that be PCS 40???)
AlLorman 04-11-2011 02:13 PM
My CG documentation is PCS as well.
Al Lorman
PSC 31 No. 55 Ann West
teejayevans 04-11-2011 07:16 PM
My hull number starts with PCS, which of course matches the CG doc.
Most likely PSC was already taken (any guesses?), so they took PCS
instead.
Tom
AlLorman 04-11-2011 07:22 PM
PSC belongs to SCORPION POWERBOATS CORP.
teejayevans 04-11-2011 07:29 PM
and they didn't take SPC because that belong to....:laugher
Tom
brokesailor 04-12-2011 02:49 AM
Does anyone know where the HIN is normally located? Engine box?
Norstar 04-12-2011 05:49 AM
Should be on the starboard stern up near the caprail. Also may be in the engine area on the forward side glass stringers.
John S
PSC 34 #201
Norstar
brokesailor 04-12-2011 06:54 PM
Thanks Norstar!
