Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #11 (permalink)
Old 04-14-2011
Seacurves's Avatar
Seacurves is on a distinguished road
Speaking of prop zinc deterioration... How long does the zinc typically last before it needs to be replaced?
Seacurves
PSC37 #359
  #12 (permalink)
Old 04-15-2011
niftynickers is on a distinguished road
Zinc usage has many variables.Whether your boat is plugged in to shore power,whether your neighbor is plugged in with current leakage even the salinity of the water you are in will affect the zinc.
The correct zinc for the C37 with a 1"shaft is a "C" zinc. Locktite (red) does help to retain the screw or you can install the screw from the inside of the acorn nut and hold the zinc on with a nylock nut.This method works fine if you haul each year and dont have to change zincs in the water.
Good luck.
Dianne and Chuck Burke S/V NiftyNickers C37 #139
  #13 (permalink)
Old 04-15-2011
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
If you're in freshwater, you shouldn't be using a zinc anode at all. You should using a magnesium one.
"Clean bottoms are FastBottoms"
  #14 (permalink)
Old 04-15-2011
Seacurves's Avatar
Really?? Magnesium? Why the difference?
  #15 (permalink)
Old 04-16-2011
Fstbttms's Avatar
Zinc anodes do not have the electrical potential to overcome the greater resistance of freshwater. Magnesium anodes are designed especially for this purpose.
HTML code is Off
Prop zinc for ps37 discoverer37 Pacific Seacraft 1 06-29-2010 10:57 AM
Broken prop shaft - saved by the zinc harbin2 Gear & Maintenance 14 05-31-2010 08:24 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
How to attach Prop Nut Zinc? preservedkillick Gear & Maintenance 6 05-15-2010 12:23 AM
zinc for flex-o-fold prop trodzen Gear & Maintenance 4 01-26-2007 12:26 AM
