Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 04-14-2011
billbalme is on a distinguished road
Prop Zinc
Can someone help out here?
The new owner of my boat (formerly "Toodle-oo!" now "Gyre") cannot find a zinc for the end of the prop - and I can't remember where I got them from. They do not appear to be listed on the WM or Defender sites...
The zinc I used screwed onto the end of the propshaft... Wasn't the best solution - would routinely fall off - but occasionally made it through the full season!
Are there other better solutions (that wouldn't compromise the line cutter...)
Thanks,
Bill Balme
Outbound 44, #27
Old 04-14-2011
adamowens is on a distinguished road
Is it like this :
Martyr Anodes – Zinc, Aluminum, Magnesium Anodes for Pleasurecraft and Commercial Craft
If it is there are several suppliers to order them from.
Adam
Old 04-14-2011
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Go here:
BoatZincs.com (978-841-9978) – The Online Superstore for Zinc Anodes
"Clean bottoms are FastBottoms"
Old 04-14-2011
boblivingston is on a distinguished road
HI All,
New to all this, but grateful for the assistance. I am the new owner of Bills PSC 37. I have attached a photo of my prop hub.
Look forward to getting to know you all.
Thanks
Bob Livingston
PSC 37 GYRE
Old 04-14-2011
Fstbttms's Avatar
I believe you have a 1" shaft. This requires a "C" cap zinc. If you have the prop nut, the letter designator should be stamped on it.
Old 04-14-2011
Thanks folks!
Thank you Fastbotttoms, And Adam. I appreciate the quick help.
The advice seems correct!!
See you out there
Old 04-14-2011
Bob - this is what it looked like.. Acorn Propeller Zinc Anodes
Bill
Old 04-14-2011
HI Bill,
Thanks for this posting and the response. I do not think what you showed me is the correct zinc, as it will not go over the cotter pin. The first reply showed a Prop nut and zinc that does fit over the cotter pin. I believe that was the correct one. I also found out I am in the water probably as we speak. Fortunately, Kyle removed the line cutter, added a donut zinc to the shaft and put the prop on and a lock nut. It is not optimal, but it is workable. Thank you ALL for the asistance !!
Old 04-14-2011
BirdBrain333 is on a distinguished road
Dear Bob, congratulations on your new boat! The link provided by Adam at the top of the page is exactly what we have on our similar vintage 37. I'm going to try some serious loctite this year to see if we can get it to stay on for a bit longer!
Jay, PSC 37 # 171, Kenlanu , STILL snowbanks between us and the open ocean!
Old 04-14-2011
teejayevans's Avatar
teejayevans is on a distinguished road
Are you sure it's not falling off because it's deteriorated?
Tom
PS31#111 Cielo Azul
HTML code is Off
Prop zinc for ps37 discoverer37 Pacific Seacraft 1 06-29-2010 10:57 AM
Broken prop shaft - saved by the zinc harbin2 Gear & Maintenance 14 05-31-2010 08:24 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
How to attach Prop Nut Zinc? preservedkillick Gear & Maintenance 6 05-15-2010 12:23 AM
zinc for flex-o-fold prop trodzen Gear & Maintenance 4 01-26-2007 12:26 AM
