Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 04-21-2011
orientalnc2010's Avatar
orientalnc2010 is on a distinguished road
rigging whisker pole
I'm planning on rigging a whisker pole on my crealock 31. I already have the line driven car, should I rig the line drive 2:1 or 1:1. What cam cleats work best on the mast? Also I am planning on a 6' t-track mounted 2' off the deck, I have a high cut clew and want to make sure I can get the pole high enough. The pole will be stored on deck not on the mast.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
Old 04-21-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
1:1 on that boat, and just size your cam cleats for whatever line you're using. There's not much load on the cars up and down movement. It's a compression load.
I guess you could go 2:1 if it's not much of a price difference. But mostly just keep the track and car lubed, or use a plastic slider.
Merit 25 # 764 "Audrey"
Old 04-22-2011
arisatx's Avatar
arisatx is on a distinguished road
You can skip the cam cleats if you go with an Antal line driver setup:
Regards,
Ted
V42#186
s/v Little Wing
HTML code is Off
Whisker pole rigging -- guys and lifts? lydanynom Gear & Maintenance 5 08-12-2010 11:44 AM
Whisker Pole? BubbleheadMd Learning to Sail 6 01-22-2010 07:01 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
Whisker Pole Jovietal Gear & Maintenance 2 07-08-2007 03:41 PM
