Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #21 (permalink)
Old 04-24-2011
lsbrodsky's Avatar
lsbrodsky is on a distinguished road
You need to look closely at any possible gasket leakage now. If you did overpressure and it sounds likely you could have water leakage to the oil or oil leakage to the engine exterior. If the engine is running fine, you may have dodged that bullet.
Larry
  #22 (permalink)
Old 04-24-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
If she's not smoking, dripping, steaming, or sputtering, then leave well enough alone and don't mess with it until she starts doing one of the aforementioned.
It's 5 o'clock somewhere:
  #23 (permalink)
Old 04-24-2011
boblivingston is on a distinguished road
Hi Bill, Hi all,
Long day (with family)
Thanks for the concern, ideas, advice and weighing in. I found no water in the OIL, which is what I meant earlier when I had it reversed. I appears the Universal Atomic is rather robust. I cannot think of much worse to do than we did, and it survived.
She's is not smoking, dripping, steaming, or sputtering, and I do intend to leave well enough peaceably alone. I believe we luckily dodged a self made bullet.
Thank you Bill, and everyone else. I will now set to work generating my next gaff for general Sailnet amusement.
Happy Easter
Bob PSC 37 #148
  #24 (permalink)
Old 04-24-2011
Mark1948 is on a distinguished road
One additional comment that no one ever mentioned to me. Some day if your exhaust is black iron pipe as many universals have it will fail and likely as not you will think you are on fire as the cabin fills with diesel smoke. Most of the pipe is wrapped with fiberglass packing so visual is difficult. If you run at higher RPM you will likely pump in more water than you can pump out. cut the RPMs get to port and replace the pipe. Not a real hard job. Just no one mentions about the exhaust system failing.
HTML code is Off
Diesel engine course in SF bay MarkSF Learning to Sail 7 05-02-2011 05:40 PM
Overheated Diesel -- What Damage to Look For? FishFinder Diesel Engine Forum 9 03-04-2010 01:30 AM
Will running cold cause engine damage? nightowle Atomic 4 6 05-10-2009 11:19 AM
Diesel engine help patrickbwells Gear & Maintenance 15 04-01-2007 04:37 PM
Diesel Engine nancisboat Crew Wanted 0 03-13-2001 08:49 AM
