Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 06-26-2011
steneck is on a distinguished road
Stuck floor hatch PSC 34
Hi folks,
I spent more than an hour today trying to lift the floor hatch in the main salon of our 34' Pacific Seacraft. It is under our table and has two finger holds. The aft one is round (without a latch) and the forward one is rectangular and rotates to unlatch (I think).
I suspect my problem is simple swelling of the wood binds the sides of the hatch. However, I used leavers, brute force and even a line that I twisted to create vertical pull without success.
Have any of you had such stuck wooden hatches? Is there a solution to this problem (literally or figuratively)?
Bob Steneck
PSC 34' "Alaria"
Christmas Cove, Maine
Old 06-27-2011
Norstar's Avatar
Coastal Carolinas
Norstar is on a distinguished road
Bob, Try carefully using a razor knife to cut the joint around the hatch. Maybe someone varnished the cabin sole as in my case and varnish is stuck in the joint?
John S
PSC 34 # 201
Norstar
Old 06-27-2011
RainDog's Avatar
Not Finished Yet
RainDog is on a distinguished road
I had the same problem and decided the problem was they were two close to each other. I forced a shim between the two boards to push them away from each other. Then used a lever to pull one up. After I had them up a cleaned all the joints really well and now they come up pretty easy. If you have a dehumidifier or AC, run it for a week before you try to reduce the swelling of the wood. This will make your life much easier.
Pacific Seacraft 34 #142
Seabrook, Texas
Old 06-27-2011
hellosailor's Avatar
Bob, if those tricks don't lift it clear, you can take a wood toggle on a bit of line (like you'd see buttoning a classic stadium jacket), push the toggle through the hole, and then put your back into lifting on that line.
It almost always is a problem of the wood getting damp and expanding, and if you sand it down a little magically the opposite happens and the board never stays put again.
Floor boards really need to be sealed on all six sides (top, bottom, and the edges) or they'll find a way to change size on you. Or, you install them a little loose and use slides or pulls that can secure them down.
Old 06-27-2011
HI Folks,
Thanks for those suggestions. I did try to run my knife along the edge but maybe a razor blade is a better tool. But as they say in Maine, "it's tighter than bark to a tree.
RainDog - I'm wondering where you drive the shim. It is least tight for and aft but I still do not have a gap. I played with a screw driver but saw that was going to become a ding and I quit.
I do have a wood toggle that I used as a lever but without success. The wood bowed but did not pop out.
Have any of you ever considered using a penetrating oil to loosen the stuck edges? Or will that make it worse? If I ever get this unstuck, I will sand them for this summer and then sand and varnish them for next year.
Bob
Old 06-28-2011
RainDog's Avatar
Not Finished Yet
I used something similar to this: Craftsman 13-1/2 in. Pry Bar Reviews - Craftsman Community and force it between the two boards. The goal is just to push them apart so there is a small gap between the two floor boards.
After I am done with this, I stick a 2 foot screwdriver through the finger hold and use it as a lever to lift the board.
Seabrook, Texas
Old 06-28-2011
Roger that
Thanks RainDog,
I have one of those at home and will give it a try. Looks like the wide edge will be less likely to ding than a screw driver.
Bob
Old 06-29-2011
RainDog - The pry bar worked. Thanks for the tip.
Bob
Old 06-30-2011
Cruisingdad's Avatar
Best Looking Moderator
You already got it out, so this info may not be for you, but for anyone else with a stuck floor board:
First, try closing up the boat if you have time and put in a dehumidifier and let her run. It may reduce the moisture content enough to manually pull out without scarring the floor. Also, check your rigging. If you have recently tuned the shrouds, you may have flexed the hull to the point you have pinched the boards. Had this happen on a Tayana, Tartan, and a few other boats.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 07-01-2011
okapi3 is on a distinguished road
I have had and solved this problem. It is due to humidity swelling the boards. For a while, I removed the stuck boards using a sail tie, in a loop, with a carabiner attached. I put the carabiner on the finger pull of the floor board and the sail tie around my hips and then by squatting and doing a quick leg press, popped the board out.
Finally, I used a hand plane and planed the edges down and then sealed them with epoxy and the boards no longer stick.
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
HTML code is Off
Dinghy Floor mxtommy Gear & Maintenance 15 02-03-2011 06:19 PM
Where to get a new inflatable floor? T37Chef General Discussion (sailing related) 6 12-06-2009 11:10 PM
Floor rot in Oday 22 NJRISurfcaster O'Day 3 06-05-2008 12:16 PM
Teak floor protection f_cousin Gear & Maintenance 4 07-07-2003 06:08 PM
Floor Hatch Repair rickandtyra Gear & Maintenance 0 07-29-2001 04:49 AM
