Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #11 (permalink)
Old 07-31-2011
BMLipiec's Avatar
BMLipiec is on a distinguished road
John,
You bring up a good point, but I have to believe that the factory would have calculated the load requirements when installing the track. I would also think that the track would spread the load out over a greater area on the deck, instead of a point load at a pad eye (although a large enough backing plate would probably mitigate that risk).
If the early PSCs had a pad eye, I wonder why they switched to the track arrangement. The pad eye would have been cheaper and easier for the factory to install. There must have been some demand for the change. Can anyone speak to why it would be benificial to adjust the backstay position?
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
  #12 (permalink)
Old 07-31-2011
johnbanfield is on a distinguished road
Folks, I am confused.
I would have thought the deck track would be for larger staysails, or leading smaller jibs inside the shrouds. I would think that their use to secure running backs would be secondary to this.
I would also think that 100% and less staysails would go to the cabin top tracks.
But I don't have a cutter, so this is all conjecture...
cheers,
John
Liberty
  #13 (permalink)
Old 07-31-2011
BMLipiec's Avatar
John,
There are two sets of tracks on Indigo, both factory installs.
The tracks on the cabin top are for the staysail sheets to adjust for the proper sheet angle, similar to the tracks on the cap rail for the jib.
The second tracks are on the deck just forward of the cockpit for the running backstays.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
  #14 (permalink)
Old 07-31-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
The tracks on deck can also be used for tight sheeting angles on the headsail to allow pointing higher into the wind.
  #15 (permalink)
Old 07-31-2011
Cool,
I will start with the cabin top ones then, and when I get my 130 cut down might add the deck tracks too. In the interim I'll just put my running backs to something strong enough, either on the rail track or up the stern.
Should I go the 1 1/4 track?
Thanks,
John
  #16 (permalink)
Old 08-10-2011
DaveMancini's Avatar
DaveMancini is on a distinguished road
John,
Yes to the 1 1/4 track.
Dave
HTML code is Off
Staysail (staysail) on a Freedom 33 freedom33 Introduce Yourself 0 03-06-2010 07:36 PM
Advantages of midboom sheeting? jbarros General Discussion (sailing related) 20 10-20-2009 10:15 PM
Mainsail sheeting arrangements Hartley18 Sailboat Design and Construction 18 03-12-2008 07:17 PM
mid-boom sheeting break on Beneteau somedaypam Beneteau 1 10-17-2007 10:33 PM
Boom-end sheeting & sail trim bobmcgov Learning to Sail 10 09-25-2007 11:30 PM
