07-31-2011
Originally Posted by brokesailor
The stbd sheet setup sounds very weird! Is the track on deck or on the cabin roof? If on deck shouldn't the sheets be run to your genoa winches? (I am also a non expert). On my 37 I have tracks and blocks on both, the coach roof track and blocks are used for a permanently installed boom brake setup. The blocks and track on the deck, inside the shrouds are used for the staysil. They run aft to the primary winches used for the headsail. The headsail track and blocks are on the caprail.
Hi, thanks for replying.
I have ordered a staysail that just reaches the gooseneck, so now I have had another look at the drawings and learned about the inboard tracks... I assume that there are for larger, overlapping, staysails. Is this the type of staysail you have? It seems for a smaller sail the cabin top ones are a better angle.
(Given the cabin top tracks, my idea for the stbd side is to save a winch by leading the sheet across to the other side through a couple of blocks.)
Cheers,
John
