07-09-2011
On my 1990 37, those bolts actually do have nuts. Getting at them required cutting a small access panel, and then covering the new hole with a small vent. It seems that some boats have aluminum backing plates and the bolts are tapped into it, some have lag bolts, and some are nuts and bolts. On my boat, I could turn the top bolt and it would just spin and spin - the nut wasn't captured.
I cut a 6" by 2" hole, starting about 1" below the base. If you start cutting, you might want to solve the problem of how to cover the hole before you do - I used a plastic vent and they come in various sizes. Also, the hole I cut was on a 37 - I can't vouch for what's behind that panel on a 40...
Craig,
s/v Luckness,
PSC 37, #234.
