Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 08-14-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Crealock 37 headsail sheeting
Is the headsail sheet supposed to go around the block and then to the winch? As you can see in the picture if I do that I run the risk of ripping off the engine blower exhaust port (happened once).
Old 08-14-2011
teejayevans's Avatar
teejayevans is on a distinguished road
Yes, it should go through the block (winches may be designed to only handle strain from 1 direction), the engine vent should be safe unless you get a lot of slack in the line and it suddenly the sail fills, even then I think the vent should be able to handle it.
Tom
PS31#111 Cielo Azul
Old 08-14-2011
SV Skalliwag #141
Thats a replacement the old one got ripped off during a tack at seatrials.
Old 08-15-2011
I guess the easiest solution would be to put a SS bar across the gap above the vent to prevent line from getting under the vent.
Tom
PS31#111 Cielo Azul
Old 08-15-2011
arisatx's Avatar
arisatx is on a distinguished road
You could also get a 2nd fairlead on the track or maybe rig a barber hauler to clear the cowl.
Regards,
Ted
V42#186
s/v Little Wing
HTML code is Off
any 30' cruisers with end boom sheeting since mid 90s tpm1950 Sailboat Design and Construction 29 12-26-2011 06:37 PM
Staysail sheeting for PSC37 johnbanfield Pacific Seacraft 15 08-10-2011 12:13 PM
jib sheeting angle choices.. Oysterbob General Discussion (sailing related) 4 07-15-2011 03:52 AM
Advantages of midboom sheeting? jbarros General Discussion (sailing related) 20 10-20-2009 10:15 PM
converting a furling headsail to a hanked on headsail mrkeith Gear & Maintenance 6 02-15-2007 02:36 PM
