Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 10-12-2011
okapi3 is on a distinguished road
Below-deck autopilot solution for a 31?
PSC 31 owners: Has anyone installed a below deck autopilot and, if so, which kind and how did you mount it, given the limited space we have in the area of the steering quadrant?
I am particularly interested in the direct drive system from Simrad--less resistance when off, quieter, and more energy efficient than hydraulic linear drive (or so they say).
Thanks for any insights,
Paul
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
Old 10-14-2011
Ouch! 155 views and no replies. Could it be that no one has ever installed a below-deck autopilot in a 31?? Well, if I succeed I will let you all know.
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
Old 10-14-2011
tdw's Avatar
tdw tdw is online now
Super Fuzzy Moderator
Seems to me that going below deck on a 31'er is possibly overkill and most definitely expensive.
Our heavy Van de Stadt 34 (steel) worked perfectly well for 15 years with a Navico Wheel Pilot and since then with a Raymarine.
That said, our new 42'er (Malo) has below deck and I prefer it to the wheel pilot if only because it is quieter. (Obviously also stronger.)
Of course you are free to do as you wish, I'm only offering an opinion which I acknowledge in advance you didn't ask for.
Other than all that surely going below deck in your boat is not greatly different to doing so in a larger vessel.
Old 10-15-2011
SecondWindNC's Avatar
SecondWindNC is on a distinguished road
You might also check with Thumper at the factory to find out whether they've done any below-decks systems, and if so what they used. The 31s and PH32s I can recall have had wheel pilots.
Carolina Wind Yachting Center Charter Manager
Who is staring at the sea is already sailing a little.
HTML code is Off
below deck autopilot e37duff Gear & Maintenance 20 03-23-2011 06:46 PM
Installing below deck autopilot on a First 310 r1texas Gear & Maintenance 1 12-27-2010 04:43 PM
best GPS solution? jjrunning Gear & Maintenance 26 02-20-2010 06:19 AM
everyone - need keel solution tho52mas Gear & Maintenance 10 09-21-2007 10:20 AM
The Trinidad Solution John Kretschmer Cruising Articles 0 06-26-2002 08:00 PM
