How low can you run your fuel tank - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 03-09-2012
Re: How low can you run your fuel tank
I found out the hard way that one should never trust the fuel gauge. Ours was reading 1/4 tank and I was going to fill up the next day.... when we ran out of fuel.
If you're going to empty the fuel tank and you have a diesel furnace, remember to shut off the diesel to the furnace so that you don't drain it and therefore have to bleed it. Luckily I can fit inside my starboard cockpit locker, because that's how I had to access the furnace intake to bleed it.
seabum is offline
post #12 of 17 Old 03-09-2012
I had a single 150L single tank and yes with about 25 liters inside and big waves (20/25ft waves) the engine had problem sucking air. I guess it is not as much the state of the sea but the size and steepness of the waves. Going up an down those big waves tilted the boat a lot and the inside tank wall was not sufficient to prevent all fuel to go to one side.
post #13 of 17 Old 03-10-2012
teejayevans's Avatar
Forget the engine, I'd have a problem sucking air in 20+ ft waves
Tom
BluesHarp likes this.
PS31#111 Cielo Azul
teejayevans is offline
post #14 of 17 Old 03-17-2012
Not Finished Yet
RainDog's Avatar
Tom
I agree. Seems to me running your engine in 20+ foot waves is poor idea. I would instead lay on the cabin sole in the fetal position and cry.
RainDog is offline
post #15 of 17 Old 03-17-2012
Sorry guys, I did not want to give the impression that I sail in storms.
Actually along the Portuguese coast you can find sometimes some really big waves that form in big Atlantic offshore storms but if the wind does not blow over 30K they are just impressive and not dangerous because they don't brake and are not short period waves.
I was talking about one day that I got some of those in passage. Nice sailing, downwind with 20K wind except that near sunset the wind died but not the waves and what has been a very pleasant sailing day turned from some hours in a rather bouncing experience, with an engine that worked in a very irregular way. We where near port but take a long way to reach there, doing about 2/3K speed
Well, near shore they break:
http://www.youtube.com/watch?NR=1&fe...&v=ihACGHa7Jvs
post #16 of 17 Old 03-27-2012
BluesHarp's Avatar
I cut the sole with a hole saw and inserted a bronze deck fill to make it easier to read my fuel gauge. Now I don't have to lift floor boards in order to verify fuel levels.
BluesHarp is offline
post #17 of 17 Old 03-28-2012 Thread Starter
That looks really nice, BluesHarp. It would be easy to ready while lying in the fetal position on the floor in 20+ wave too. I thought about doing the same thing with a glass lens, but in the end decided that it was not that much of a chore to lift the lid when I needed to check the fuel level, which really, for me, isn't that often.
johnharch is offline
Fuel tank for First 42 first42 Beneteau 16 12-26-2014 11:01 AM
Need a new fuel tank AlLorman Pacific Seacraft 26 09-16-2011 12:08 PM
PSC 34 fuel tank mondofromredondo Pacific Seacraft 8 11-17-2009 05:22 PM
11.0 Fuel tank S2 Dave S2 1 08-14-2006 10:30 PM
Fuel tank doalmo Gear & Maintenance 0 10-13-2004 02:39 PM
HTML code is Off
