01-24-2012
When we first filled the sinks on Irish Eyes, we found what the surveyor didn’t; the starboard side sink had been perforated by the salt water from the sea water tap that fills that sink. The temporary fix was quick but crude. I put on rubber gloves and rubbed Bondo over the bottom of the sink until Bondo worms came out the many almost microscopic holes in the stainless steel. When it hardened I brushed the worms away, and the sink was again usable.
I was unable to locate a Polar sink the size of the original, but I did find a slightly wider (port-starboard) and narrower (fore-aft) Sandvick sink at a great price at Sailors Exchange in St Augustine. I had to make the hole wider (a saw) to allow the sink to fit with the starboard bowl touching the exterior of the shelf filled cabinet and bringing the port sink flange to the edge of the trash can finger hole depression. The new sink did not have a large flange on the far side of the sink, so the fresh water foot pump tap (port side), the salt water foot pump tap (starboard side), and the hot and cold pressurized water tap (middle) all had to go in a new bit of plywood, fiberglass, resin, and gelcoat which I added to make a space for them. I also added a pump dispenser for Joy detergent.
The new sink was too close to the trash can hole for the existing trashcan cover to fit. Rather than trimming it down, I replaced it with a hinged lid made from oak and teak and also made a matching cutting board with its bottom trimmed to closely fit the port sink and loosely fit the starboard sink. Later, at Target I lucked into a plastic basket that fits the port sink and holds fruit and such like the more normal galley vegetable hammock. A water drop shaped teak turnbutton holds the trash can lid open in a seaway. The cutting board has four small rubber feet on its bottom which allow it to span the raised covers in the middle of our fixed salon table to serve as a trivet for a hot casserole dish or as a bread cutting board during meals.
Bill Murdoch
