staysail arrangement - SailNet Community
post #1 of 19 Old 01-17-2012 Thread Starter
orientalnc2010's Avatar
Everything on a sailboat is some sort of compromise, the staysail arrangement on a cutter is no exception. Permanently rigged with a furling unit or removable inner forestay with hanked on staysail, which one makes you happy?
If you had it to do over again what would you choose.
I mostly river sail at this time, very wide river, but plan to do more cruising this season. I don't like the idea of going forward to rig a stay and hank on a sail when it's starting to blow hard. On the other hand I don't like the idea of having to tack the headsail through the slot. What to do?
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
orientalnc2010 is offline
post #2 of 19 Old 01-18-2012
Courtney the Dancer
jrd22's Avatar
When the wind is light and all is well having the staysail on a furler is a PITA. When the wind changes unexpectedly and all of a sudden it's blowing 30 knots, having the staysail on a furler is a blessing. Compromises, life's full of 'em.
FYI- tacking the headsail is no problem, just leave the staysail sheeted and let the headsail slide along it and thru the slot, then release the staysail (OK, sometimes it gets hung up in very light wind, no biggee, good excuse to get off my rear and do something).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 19 Old 01-18-2012
Coastal Carolinas
Norstar's Avatar
We installed a Harken furler on our inner stay and converted from hanked on staysail. No regrets on this decision. Tacking while keeping the staysail sheeted in works ok as John mentioned above or we usually just furl in the headsail enough to clear the inner and let it back out after the tack. As you mentioned, everything is a compromise but we feel this one has been a good trade off.
John S
Norstar
PSC 34 #201
Norstar is offline
post #4 of 19 Old 01-18-2012
Well, It somewhat depends on the size of your headsail. With our old 150 genoa, tacking with the staysail stay on was somewhat of a pain. But, now with a 110 Yankee (which we love!), the Yankee tacks quite easily and we have not once removed the staysail stay as we used to whenever it was not in use. So, if I had it to do over again, I'd go with a Yankee headsail and furling staysail.
An added advantage of this arrangement is that you could then furl the staysail down when it is really blowing. On an overnight passage last summer the wind increased to sustained 38-42 knots and we were doing 6.5 to 7.2 knots under staysail alone (downwind) and needed to slow down to avoid a night time entry into our destination. Needless to say I was not too thrilled with the idea of going forward and taking down the staysail to put up the storm jib. A furler would have been a delight that night.
Jay
PSC 37, Kenlanu, Abacos, the Bahamas
BirdBrain333 is offline
post #5 of 19 Old 01-18-2012
Mermaid Hunter
SVAuspicious's Avatar
I think you have the issues exactly right.
My response to those issues is to day sail with the inner forestay stowed. When headed offshore I rig the stay, hank on and bag the staysail, and run the sheets. As you note, when you want the staysail it is too late to rig it. This approach has worked well for me for years, albeit on boat that is not a PSC.
SVAuspicious is offline
post #6 of 19 Old 01-18-2012
svjobeth's Avatar
This is a variation on what we've decided to do aboard Jo Beth. The majority of our sailing is short coastal trips just offshore or in sounds/rivers. We couldn't find a way to detach and stow the inner forestay to our liking, and Jo Beth came with a lightly used 120 or 125 genoa, so we've decided to remove the inner forestay altogether and sail as a sloop. Our running backs are in pretty bad shape anyway.
When we start doing more extended offshore trips, we'll revert her back to a cutter - with new running backs and hopefully, a new suit of sails.
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #7 of 19 Old 01-18-2012
DaveMancini's Avatar
We usually sail with either the 110 jib or staysail only, rarely both. We keep the staysail bagged on the stay until we need it. The bag opens at the top. When the wind is too much for the jib, we drop it and run up the staysail. We find the staysail easy to tack by easing the lazy sheet after the staysail fills on the new tack. We do this after taking all the slack out of the soon to be working sheet. Then we fully trim the working sheet. Both sails are hanks on.
Most of our sailing is offshore. If we sailed mostly inland, our strategy might be different.
Dave Mancini
PSC 34 #305 "Swan"
DaveMancini is offline
post #8 of 19 Old 01-18-2012
teejayevans's Avatar
I have detachable stay, I always rig the staysail when going offshore, if I have to slow down to wait for daylight, I just sail until I get close then heave-to, no need to go forward. My 130 doesn't tack that well and I really enjoy not having the stay in the way when river sailing.
Tom
PS31#111 Cielo Azul
teejayevans is offline
post #9 of 19 Old 01-19-2012
SV Skalliwag #141
brokesailor's Avatar
I also do as Auspicious. For offshore work rig the staysil and have it on the ready. If you know the wind will pike up then deploy the staysil with the headsail. Once it starts blowing then just furl in the headsail. Hopefully you also reefed the main ahead of time so no need to go foward.
Daysailing always set up your sail plan before leaving the dock.
brokesailor is offline
post #10 of 19 Old 01-19-2012
If I mostly river sailed, as you say, I would certainly remove the inner forestay. Rivers will usually require more tacking for other boats and granite. I wouldn't expect you to get so far from port in a river that a heavily reefed jib wouldn't suffice in heavier wind. Maybe not as efficient, but certainly workable. When I was going offshore, I would reattach the staysail.
We actually come at this from a different angle. Our boat is designed as a sloop, but has a removable inner forestay as an option. We have that option, with the forestay wound up in a cockpit locker. We have yet to feel the need to install it for a passage. There are downsides to a heavily reefed roller furling genny, but it has worked fine for what has been mostly coastal cruising on this boat, with one annual exception. Dealing with the staysail hasn't been considered a lesser evil yet.
Jeanneau 54DS
Minnewaska is offline
Cabin Heater Type and Arrangement SVArgo Pacific Seacraft 50 01-16-2014 08:45 PM
Staysail (staysail) on a Freedom 33 freedom33 Introduce Yourself 0 03-06-2010 07:36 PM
Very bad bilge pump arrangement mitiempo Gear & Maintenance 1 02-12-2010 08:16 PM
O'Day 28 Main sheet arrangement FourSeasMilford Gear & Maintenance 9 03-08-2009 10:42 PM
Helm Station Arrangement USCGRET1990 Boat Review and Purchase Forum 49 05-19-2007 10:29 PM
HTML code is Off
