02-01-2012
Our boat, JUNO, is a PSC 40 not a 37, but we opted for a mast-mounted line control 50/50 (aluminum/carbon) pole. Here was our thinking. That pole is a lot of weight and length for one person (we cruise as a couple) to be fumbling and stumbling with on a rolling deck. With one end anchored to the mast and the other controlled by an "uphaul," it is much easier to rig -- and therefore 1) safer and 2) more likely to be used. And, yes, we use it and like it very much. The 50/50 saves some weight over the aluminum, which also eases handling (also less weight aloft, I suppose). All carbon might be even better, but it is pricey.
One last thought: be sure to size your pole properly. There's a big difference between a working jib and a 140% genoa (not only would the pole need to be longer, but it would be bearing a much heavier load, as well). On JUNO, with a 120% genoa (J=18.5), we use the 13-24 pole.
Roger Lopata
JUNO
PSC 40 -- #46
