Whisker pole recommended for PSC 37? - SailNet Community
post #1 of 18 Old 01-29-2012 Thread Starter
Seacurves's Avatar
I just got back from Strickly Sail in Chicago. Attended a short-handed sailing seminar where the speaker recommended a Forespar whisker pole for downwind sailing. I was wondering if other PSC owners have found these worth the coin and added boat stuff. I sail the Great Lakes, so not sure if that would influence your recommendation.
Boy did I walk away from that show ready to prep my boat for the 2012 season! I am sure, exactly what they intended! Jimmy Cornell was a beacon of information, a real add to the show. Nice.
Seacurves
PSC37 #359
Seacurves is offline
post #2 of 18 Old 01-29-2012
I have a PSC 34 and found the spinnaker pole it came with was very unwieldy to work with for downwind sailing. Since I don't fly a spinnaker (only an assymetric) so last summer I switched over toe a whisker pole. It works great. You have to be careful not to crank it down against your shroud. The whisker holds the jenny out nicely, it is light and easy to handle.
There's my two cents.
Bob Steneck
PSC 34 "Alaria"
Christmas Cove, Maine
steneck is offline
post #3 of 18 Old 01-29-2012
I have a Caliber 33 with a whisker pole and use it pretty often on long stretches. Makes in possible to sail way deeper in light winds than you could otherwise. It isn't the easiest thing in the world to deal with but not too hard either. Nice thing is you can roll up the genny without taking it down if you need to shorten sail suddenly for a squall or whatever
sck5 is offline
post #4 of 18 Old 01-29-2012 Thread Starter
Seacurves's Avatar
So a whisker pole seems to be a well-respected piece of equipment that cruising sailors would rather have than a simpler boat. Appreciate you both weighing in here!
Seacurves
PSC37 #359
post #5 of 18 Old 01-30-2012
arisatx's Avatar
SC:
I think once you start cruising longer distances, you'll find it invaluable. We've had one up for days, on the genoa. Easy to "douse" too. John Kretschmer's video does a nice job explaining:
Forespar Whisker Pole - YouTube
Now, one pole or two? Aluminum, Aluminum/Carbon, or all Carbon? Which pole car? Decisions, decisions - gives us something to do over the long winter.
Here is one of my favorite YouTube videos of a Dana 24 going downwind with twin poles
Singlehanded sailing with twin headsails view from a kitecam - YouTube
Regards,
Ted
V42#186
s/v Little Wing
Last edited by arisatx; 01-30-2012 at 09:37 AM. Reason: Added link to twin poles video
arisatx is offline
post #6 of 18 Old 01-31-2012
valis's Avatar
A whisker pole is great, especially for long runs. I've spent days running downwind wing and wing using a whisker pole.
A regulation-length spinnaker pole is really too short to fully pole-out a big genoa, so an extending whisker pole is a good solution. The whisker pole is generally less sturdy than a spin pole so you need to be careful in big winds. On a PSC 37 you can probably manage the weight of an aluminum pole, but the carbon ones are certainly nice (and expensive).
Paul Elliott
S/V VALIS - PSC 44 #16 - Friday Harbor, Washington
valis is offline
post #7 of 18 Old 01-31-2012 Thread Starter
Seacurves's Avatar
Appreciate the additional input! Looks like a whisker pole would be very valuable when I am sailing up/down Lake Michigan coast or crossing in the right winds, especially if I am really trying to get somewhere (i.e. not daysailing). I definitely would want the lighter pole for manageability. The videos make it look like more sailing fun!
Seacurves
PSC37 #359
post #8 of 18 Old 01-31-2012
bill norrie
PSC#& whisker pole
YES definitly "need " a whisker pole, we have a mast attached spinnaker pole and a 17 ft "whisker pole" for trade wind sailing a must in my book I cheaped out on alluminum pole and would get a carbon pole next time they are are a handfull for sure but fun and required to run down wind in any kind of rolling seas ,after all she is a sailing m
achine afterall. fun cheers, BIll
SV Terrwyn
BillNorrie is offline
post #9 of 18 Old 01-31-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
SV Terrwyn
Bill,
Does that mean you deck mount the whisker pole ?
rgds
Andrew
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #10 of 18 Old 01-31-2012
bill norrie
no not quiet , we lash the whisker pole in the forward lifelines gennerally underway BUT have a ring on the mast and a cleat beside the granny bars where we can put the whisker to bed upwards leaning to open up the fordeck for living. options ,
Yours,
Bill
SV Terrwyn PSC 37
How to buy a whisker pole.... MedSailor Gear & Maintenance 11 02-28-2010 07:28 PM
Whisker Pole? Ajax_MD Learning to Sail 6 01-22-2010 08:01 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 03:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 03:10 PM
Using A Whisker Pole Dan Dickison Learning to Sail Articles 0 04-23-2001 09:00 PM
HTML code is Off
