02-03-2012
It's not a bad idea to have a few feet of excess sheet, in case you need to replace a chafed eye. You may need to tie a quick bowline (or buntline hitch, etc), as an emergency repair, so allow enough extra for that.
Also, it's common to end-for-end your lines once they start showing signs of chafe. If the wear and tear is at the merely cosmetic stage you can turn the line around, re-splice any shackles, and now the chafe points will be wearing on fresh sections of the line. This can essentially double the lifespan of some lines. You do need a few feet of extra length to be able to do this.
Paul Elliott
S/V VALIS - PSC 44 #16 - Sausalito, California
