Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
Old 01-30-2012
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Replacing running rigging
I am looking to replace my jib and main sheets. Never shopped for sheets before. Would a polyester double braid like Sta-set from New England Ropes be a good choice?
What size do other 37's use out there? The sheets on my boat are so oversized they do not fit the winch self tailer or the clutches.
Thanks!
Old 01-30-2012
Lake Superior Sailor is on a distinguished road
I like Sta-set and use it on my boat. You need to get what fits your winches & clutches..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Old 01-31-2012
valis's Avatar
valis is on a distinguished road
Sta-Set X is also good. It uses a parallel-lay core (not braided) so it has slightly less stretch than regular Stay-Set. Low-stretch is a good thing for sheets and halyards.
Agree, get what fits your clutches and blocks, probably 7/16" or 1/2". If you go too small it's hard on the hands and your clutches won't work. Too big and you have excess friction and wear.
Paul Elliott
S/V VALIS - PSC 44 #16 - Sausalito, California
Old 01-31-2012
arisatx's Avatar
arisatx is on a distinguished road
Thanks!
Broke:
Our old PSC37 had 7/16" NER Sta set double braid for the mainsheet specified on the packing list, but the owner's manual spec'd 1/2" double braid. We eventually replaced it with 1/2" NER Regatta braid.
We had a 120 Genoa, IIRC and it had NER staset 1/2" sheets.
Regards,
Ted
V42#186
s/v Little Wing
Old 02-01-2012
teejayevans's Avatar
teejayevans is on a distinguished road
Halyards I can understand low stretch, but sheets, I would think a little flex would be a good thing, in case of unattended jibe or gusting winds for example.
Tom
PS31#111 Cielo Azul
Old 02-01-2012
Gary M's Avatar
Gary M is on a distinguished road
It is not as important with sheets as halyards, but if you have stretchy sheets then ever time there is a little puff some of it absorbed by the sheets and not transferred to the boat as drive.
Old 02-01-2012
valis's Avatar
Correct -- stretching generates heat, and that's where the lost power goes. Stretchy sheets can also make it more difficult to keep the sails properly trimmed.
Honestly, for cruising you're not going to see much if any difference between Stay-Set and Stay-Set X (or the high-performance racing lines). Standard double-braid (Stay-Set) is probably easier to splice, too.
For a cruiser, probably the main reason to consider a higher-performance line is when the line size would otherwise become too large for convenience. With a PSC37, 5/16" or 1/2" poly double-braid line such as Sta-Set should perform well enough, and the diameter is good for comfortable handling characteristics. On a bigger boat, 1/2" Sta-Set just won't do the job as well, so it makes sense to look at hi-tech lines.
Paul Elliott
Old 02-02-2012
Seacurves's Avatar
Seacurves is on a distinguished road
So how do you determine when running rigging should be replaced? Are there different practices for halyards vs sheets?
Seacurves
PSC37 #359
Old 02-02-2012
valis's Avatar
I just look for wear.
Jibsheets typically chafe at the sail clew attachment and where they rub against the shrouds. Halyards can chafe at the blocks, and at any shackle eyes. Look carefully inside the eye splices, the line can get very worn here and still look OK at first glance.
Sunlight can also degrade the covers on the sheets and halyards, and this shows up as fuzz, etc.
Don't forget your control lines (furling, vang, reefing, preventer, etc). Unspool all the line from any furling drums, and inspect every inch.
Other than sunlight and chafe, lines will last a very long time in normal use. If a line looks good it probably is good.
Paul Elliott
Old 02-03-2012
Seacurves's Avatar
Thanks Valis!
With your recommendations in mind I have at least one line that is very ready for replacement. So another quick question: what is a good way to calculate ideal line length? For example, right now my mainsheet seems way long and is always coiled up with an unused 15+ feet.
Would appreciate any guidance.
Seacurves
PSC37 #359
HTML code is Off
replacing running rigging bonito General Discussion (sailing related) 14 02-07-2012 08:33 AM
Replacing Running Rigging Harborless General Discussion (sailing related) 8 05-30-2011 10:15 PM
thinking about replacing running rigging bonito Cal 5 01-21-2011 09:05 AM
C30 running rigging stumartell Gear & Maintenance 1 12-22-2010 01:17 AM
Replacing Running Rigging Duke 7184 Gear & Maintenance 34 06-04-2007 07:44 PM
