converting sloop to cutter orion 27 - SailNet Community
post #1 of 5 Old 03-01-2012 Thread Starter
anyone converted an orion 27 sloop to a cutter rig? any structural work required?
reed1v is offline
post #2 of 5 Old 03-01-2012
Senior Slacker
SlowButSteady's Avatar
Assuming that you'll be attaching the tack of the staysail at the stem, I wouldn't think that you would need to beef up the deck or anything. However, you will probably need to add running backstays. Take a look at other Orions and see how they rigged their staysail.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 5 Old 03-01-2012 Thread Starter
orion 27 have running backs? the ones i saw did not seem to have such.
reed1v is offline
post #4 of 5 Old 03-01-2012
Senior Slacker
I looked at a few pics on the web and it would appear that many Orions with a staysail don't have runners. However, my search did come across a couple of mentions of such. My guess is that most of the time the mast wouldn't need the extra support. But, if one got caught in really nasty conditions, where it would be logical to use a deeply reefed main and staysail without a jib, runners might very well keep the mast from buckling (or at least give the skipper one less thing to worry about).
post #5 of 5 Old 03-02-2012
DMD
I owned a 1983 factory cutter-rigged Orion. You will need to add a forstay to fly the staysail on. The attachments for the forestay consisted of a welded on attachment point on the front of the mast, and a lower chainplate on top of the aft end of the bowsprit. The lower attachment was simply a bent stainless steel tang (about 1.5" wide X 3/16 thick) that was secured under one of the bolts that held the bowsprit down to the deck. Our boat (as did most cutter rigged Orions) had a self tending staysail set up with a boom. There was a traveller track for the staysail sheet just in front of the mast. The staysail sheet then ran back on top of the cabin to a cleat beside the companionway. Some Orions didn't have the staysail boom, but I thought it worked well and liked it. We did not have running backstays. Lefiell in Los Angeles built the original spars, and may have the dimensions of the boon if you decide to go that way.
The Orion is a great boat, we lived aboard and cruised the west coast of Mexico, no problems.
Regards,
Dave
DMD is offline
Sloop vs. Fractional Sloop vs. Cutter Epiphany Boat Review and Purchase Forum 39 01-31-2016 08:12 PM
converting a sloop to a schooner rig robwilk37 General Discussion (sailing related) 16 04-16-2010 11:48 AM
Converting to cutter rig. Gaspilot Gear & Maintenance 7 07-18-2008 01:53 PM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 5 07-11-2007 10:33 AM
turning a sloop rigged cutter into a cutter (different) aurielthirtyfour General Discussion (sailing related) 3 07-10-2007 08:37 PM
HTML code is Off
