Cetol on the caprail - SailNet Community
 7Likes
post #1 of 18 Old 03-22-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Wild ass guess: How much cetol should I purchase for 3 coats on a Crealock 37, starting from bare wood after stripping? Planning on doing it on my vacation and I don't want to come up short. Using Silkens Cetol. TIA
brokesailor is offline
post #2 of 18 Old 03-22-2012
Superior Sailor
Squidd's Avatar
Re: Cetol on the caprail
Might as well get a gallon, the stuffs not gonna go bad if you keep it sealed and you will need more next year anyway...
You also may find that if you scuff sand after the third coat and put two more on it'll really brighten up the woodwork...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #3 of 18 Old 03-22-2012
CLucas's Avatar
Send a message via AIM to CLucas
Consider topping with at least 2 coats of Cetol Marine Gloss.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #4 of 18 Old 03-22-2012
T37Chef's Avatar
FYI... Cetol Natural is much nicer than the original orangy tinted one... followed up with a few coats, usually 3 of gloss and you should have a nice finish.
jrd22 and Tempest like this.
Shawn
T37Chef is offline
post #5 of 18 Old 03-22-2012
One of None
deniseO30's Avatar
The stuff, gets thick in the can if you don't use it. I heard about turning the can upside down when your done and you reseal the top. that way the skin forms on the actual bottom. I've yet to try that trick myself but will be soon!
jrd22 likes this.
My last project!
deniseO30 is offline
post #6 of 18 Old 03-22-2012
poopdeckpappy's Avatar
1qt of each ( color and clear gloss ) natural teak looks really nice as well as traditional, the light I would stay away from
3 coats of color and 2 of clear should have more than enough to do your caprail
Tempest and Bilgewater like this.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #7 of 18 Old 03-22-2012
Tartan 27' owner
CalebD's Avatar
On the Cetol can the instructions recommend 3 coats of Natural Teak (superior to the other flavors IMO) and 2 coats of the clear Gloss. 1 day to cure between each re-coating.
If you don't want to run out I'd get 2 qts. of Natural Teak and 1 qt. of the gloss. I doubt you would use it all but I don't know how wide your cap/toe rails are.
Everybody has one:
CalebD is offline
post #8 of 18 Old 03-22-2012
T37Chef's Avatar
It is two coats isn't it, hahaha, its been awhile I guess
Shawn
T37Chef is offline
post #9 of 18 Old 03-22-2012
Yep, 2 clear coats; and REMEMBER the maintenance coats are done with clear only, no color.
This is were people go wrong, they use color on maintenance and that when things go ugly
1974 Ranger 33
post #10 of 18 Old 03-23-2012
DaveMancini's Avatar
I used 2/3 of a quart of "Natural Teak" to do the caprails (3 coats) and rubrails (6 coats) on our 34. This was from bare wood.
Dave Mancini
PSC34 #305 "Swan"
DaveMancini is offline
Caprail edge rub strake? GBurton Gear & Maintenance 0 06-11-2009 10:43 PM
new cetol fishboyneil Gear & Maintenance 44 07-05-2008 09:15 PM
Wood for replacement caprail? snider General Discussion (sailing related) 1 05-26-2008 09:41 PM
Re-bedding teak caprail dhornsey Gear & Maintenance 5 10-25-2007 11:08 PM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 04:12 PM
HTML code is Off
