Cabin interior hatch fastenings - SailNet Community
post #1 of 5 Old 04-29-2012 Thread Starter
On my PSC 32 PH I have eight cabin interior hatches which rely on gravity to stay in place. All are normally overlain by seat cushions. I would like a more reliable method to keep them in place (for heavy weather).
The cabin sole hatches have hatch handle latches, which are excellent but expensive, and require much drilling/routing for installation. Barrel bolts, etc., are far cheaper, but would probably wear on the cushion bottom.
So what fastener, if any, do you use?
Drifting is offline
post #2 of 5 Old 04-29-2012
Re: Cabin interior hatch fastenings
I wonder if something like this:
http://www.amazon.com/National-Hardware-V83-1-Button-Plated/dp/B002KFZVMA/ref=sr_1_174?s=hardware&ie=UTF8&qid=1335755633&sr=1-174
..might do.. lower profile than a barrel bolt. They are similar to the old wooden screen door latches we used to have way back when.
Faster is online now
post #3 of 5 Old 04-30-2012 Thread Starter
Thanks - that is smooth and low profile, though only has the strength of one screw. I'll see if I can find it with a less corrodable finish than zinc plating...
Drifting is offline
post #4 of 5 Old 05-12-2012
ralopata's Avatar
I'm attaching photos of the factory-installed latches from JUNO (PSC 40--#46). They appear to involve no routing of either the wood on the locker cover or the fiberglass on the seat. They do sit up slightly above the surface, but so far (11 years) they haven't caused any abrasion to the cushion bottoms. I believe they are made by Perko and can be found in most marine catalogs.
Fair winds,
Roger Lopata
JUNO
PSC 40 -- #46
Currently Rock Hall, MD
ralopata is offline
post #5 of 5 Old 05-13-2012 Thread Starter
Excellent, Roger, I had not come across them:
Door buttons; Perko and Sea-Dog, various materials, with and without springs.
Drifting is offline
Interior hatch trim gregreinhard Gear & Maintenance 1 03-10-2010 04:29 PM
Wood Interior Cabin Freesail99 Gear & Maintenance 23 11-20-2007 11:34 PM
Interior Cabin Walls FullandBy Gear & Maintenance 44 10-03-2007 10:35 PM
fastening to cabin fiberglass cabin interior marcusn Gear & Maintenance 3 09-06-2007 07:04 PM
Looking for a cover for the back (interior) of a thru Cabin Speaker mount. geary126 Gear & Maintenance 5 02-17-2007 06:13 AM
HTML code is Off
