C37 Anchor Locker Partition - SailNet Community
 1Likes
post #1 of 12 Old 05-23-2012 Thread Starter
Our C37 came to us with a single anchor on 20' of chain and 250' of three-strand nylon. We'll soon be adding a second anchor with a similar rode.
Our anchor locker is divided into two compartments by a lower partition that ends about 18" from the underside of the deck. Problem is that the existing rode more than fills the starboard compartment, with the last 50 to 100 feet spilling over the partition to port. Since we don't want to skimp on rode length on either anchor, so we are looking for an simple way to keep the two rodes separate.
Seems like all would be well if the partition ran all the way up to the underside of the deck. Most appealing suggestion so far is to close the gap between partition and deck with a net or, better yet, with 1" webbing.
Would greatly appreciate any tips or ideas out there.
S/V Annie
Crealock 37
#297
Time Traveler is offline
post #2 of 12 Old 05-23-2012
arisatx's Avatar
Re: C37 Anchor Locker Partition
TT:
You could go Yale Brait (or equivalent) with the rode to reduce volume.
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #3 of 12 Old 05-23-2012
On Crazy Fish I have 300 feet of chain and about 5 feet of line (to be able to quickly cut it free) on the starboard anchor and about 30 feet of chain and something like 150 feet of line on the port anchor - starboard anchor is a 45 lb CQR and port anchor is a 33 lb Bruce.
There is a division between the two, but the starboard anchor takes up more of the space at the bottom of the anchor locker.
I have been looking at replacing on the line with something like the Yale Braid mention in the previous post - particularly on the stern anchor which if not packed tightly spills over into the
propane locker.
Marc Hall
Crazy Fish, Crealock 37, Hull 207
MarcHall is offline
post #4 of 12 Old 05-23-2012
DMD
On our '37 we had the same issue with rode from one half of the locker spilling over to the other half. We added a removable extension to the fore-aft divider made from 1/2" plywood. It is held in place on top of the existing fore-aft divider by two pieces of 1/8" X 4" side aluminum strip, one screwed to each side of the divider forming an channel for the extension to sit in. So far it has worked well, and slides out to give more access if needed.
Dave
Crealock 37 #151
"Eowyn"
DMD is offline
post #5 of 12 Old 05-24-2012
S/V Argo-Pacific Seacraft
SVArgo's Avatar
I'd second Dave's comment. You really want a solid material, web or net is going to foul the rode.
We've had a problem with this as well, a bight of chain will get caught on the lip, then all the other chain will stack up to the hawsepipe, jamming up the windlass. Then someone has to run down below, clear it, and come back on deck. Makes for a really irritating anchor evolution.
Also, depending on your cruising grounds and ambitions, you may want to consider going with an all chain rode on your other anchor. That's the setup we use, and it's been pretty good to us. 45 lb CQR with 150 ft of 3/8" chain. We use this most of the time, it's easier to veer, set, weigh, and retrieve, and gives a lot of peace of mind.
Ryan
Ryan Roberts
S/V ARGO - Pacific Seacraft 37 Hull No. 309
SVArgo is offline
post #6 of 12 Old 05-25-2012
SV Skalliwag #141
brokesailor's Avatar
Any of you guys have pictures of your foredeck layout? Do you have two separate hawsepipes?
brokesailor is offline
post #7 of 12 Old 05-28-2012
DMD
No pictures handy, but yes we do have two separate hawse pipes. I assume the setup is original from the factory, but don't know for sure. The starbord side rode leads to the windlass, and through a hole in the the deck. The port side rode goes through a bronze deck fitting (with cap) directly into the anchor locker.
Dave
Crealock 37 #151
"Eowyn"
DMD is offline
post #8 of 12 Old 05-31-2012
teejayevans's Avatar
The 2nd hawsepipe was an option on the 31, so all might not have it.
Tom
PS31#111 Cielo Azul
teejayevans is offline
post #9 of 12 Old 06-02-2012
Not Finished Yet
RainDog's Avatar
Originally Posted by arisatx View Post
TT:
This is what I did on my stern anchor. Great product.
Be careful with brait if you use a rope/chain gypsy. The rope part of the gypsy most likely will not be able to grab the brait like it does a three strand line. I would test a short piece before buying several hundred feet.
RainDog is offline
post #10 of 12 Old 06-02-2012
A suggestion for those who are working in the chain locker of a C37,while in there take heavy gauge plastic and line the v-berth bulkhead inside the a-locker with the sheeting to prevent water from entering the port side cabinets .I have taken blue water over the bow and water enters thru the hawse pipes soaking those cabinets even with the cover on the port hawse and the windless hawse stuffed with plastic.The plastic also helps the chain and rode slide down into the locker.For the chain clogging problem I use my manual windlass handle poked into the hawse to distribute the chain.
Good luck,
Dianne and Chuck Burke S/V NiftyNickers C37 #139
souljour2000 likes this.
niftynickers is offline
E32 anchor locker mod Ritchard Endeavour 2 07-09-2012 08:24 AM
Crealock 37 Anchor Locker BirdBrain333 Pacific Seacraft 5 11-18-2010 05:54 PM
Anchor Locker Renovation QuickMick Gear & Maintenance 2 08-26-2010 04:53 PM
Check your anchor locker... riphonda Sabre 1 04-14-2009 06:18 AM
Anchor Locker Drain playinthru08 Gear & Maintenance 8 09-01-2008 01:19 PM
HTML code is Off
