Galley sinks in Crealock 37 - Page 2 - SailNet Community
post #11 of 19 Old 06-15-2012
Re: Galley sinks in Crealock 37
Some just install a manual diaphragm bilge pump, and pump it out thru an above water thru hull, just below the deck line.
Brent Swain is offline
post #12 of 19 Old 06-15-2012 Thread Starter
Anna Marie PSC 37
macmhuirich's Avatar
Thanks, everybody. Some great input here.
MacMhuirich
macmhuirich is offline
post #13 of 19 Old 06-16-2012
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Friends of ours with a macerator pump in their sink drain were wrongly accused of pumping out their holding tank in a marina by an employee who heard the pump running and assumed the worst.
Bill Murdoch
Irish Eyes
1988 PSC 34
wsmurdoch is offline
post #14 of 19 Old 06-17-2012
s/v Pelagic
Our sinks started backing up about the same time we put bottompaint over the waterline stripe.
We also installed a macerator on the galley sink drain which worked well for a while but then started having trouble pushing drain water against the backpressure of the seawater. The initial workaround was to tee the outlet into the deck drain at the water line which worked fine but as someone else noted the noise of the pump is very noticable.
I then tried a long length of outlet hose in a loop up near the diesel deck fill and back down to the sink drain through-hull. This fixed the backpressure and the noise problems and has been working for a few years now.
John
s/v Pelagic
C37 yawl #22
jnewcomer is offline
post #15 of 19 Old 06-17-2012
DMD
Since the subject of macerator pump noise has come up, I'll offer a few tips we learned with our galley sink macerator. Originally our pump was mounted horizontally, and when it pumped the hose from the sink empty the noise that came up through the sink was like a car horn blasting. We re-mounted it vertically with the inlet down so that the hose from the sink formed a "J" trap shape. The reduction in noise caused by the little bit of water remaining in the bottom of the hose is significant. Also, allowing a bit of extra hose length in the "J" section of hose creates a sump effect, that reduces how often you need to use the pump. Our pump outlet hose is routed up to deck level inside the galley cabinets, then back down to it's own thru-hull just above the waterline. I have been thinking of adding a vented-loop to the hose, but have not done it yet.
Dave
Crealock 37 #151
"Eowyn"
DMD is offline
post #16 of 19 Old 11-11-2012
deluxe68's Avatar
I was on a 40' and roughly measured the sinks as 8" deep, are the sinks on the 37 ten inches deep? Are the new boats the same?
deluxe68 is offline
post #17 of 19 Old 11-21-2012
This should prove interesting for you:
svluckness.blogspot.com/2012/10/raising-galley-sink-in-pacific-seacraft.html
thor is offline
post #18 of 19 Old 11-22-2012
deluxe68's Avatar
I saw that a few weeks ago. I think it would be simpler to just get a new 8" sink.
deluxe68 is offline
post #19 of 19 Old 11-26-2012 Thread Starter
Anna Marie PSC 37
Regarding the question about the sink depth in a PSC 37 - the sink depth (at least in the 1989 model) is 10 inches.
MacMhuirich
Crealock 37 brokesailor Pacific Seacraft 8 06-13-2012 06:30 AM
Crealock 37 brokesailor Pacific Seacraft 3 05-31-2011 06:26 AM
Crealock 37 billbalme Pacific Seacraft 4 10-17-2010 08:38 PM
Looking for my old Crealock 37 billiesma General Discussion (sailing related) 4 02-14-2010 09:39 PM
IKE vs. Crealock 37: Shibumi ellenwhite2 Pacific Seacraft 5 10-06-2008 10:15 AM
HTML code is Off
