Starter Relay - SailNet Community
post #1 of 5 Old 07-11-2012 Thread Starter
Starter Relay
We occasionally experienced trouble starting our engine once in a while. Usually it was when it was hot, like at a fuel dock, or a quarantine dock - places you don't want to get stuck. Motors and switches were replaced and the problem persisted.
At a Mack Boring seminar I asked the instructor if this issue was a starter issue with Yanmars. He did confirm the problem and said Yanmar now installs starter relays to activate the solenoid. Interestingly, several others in the audience shared the same problem.
I've now installed a Yanmar relay, part number 129100-77910, and will report back if our issue is truly resolved.
Sam - PSC34 - s/v Grace
samchristo is offline
post #2 of 5 Old 07-11-2012
HANUMAN
RobGallagher's Avatar
Starter Relay
Having a similar problem. Can take a few pushes of the button. Replaced switch and button.
HANUMAN
'88 C&C 30 MKII
NOANK, CT
RobGallagher is offline
post #3 of 5 Old 07-11-2012
Re: Starter Relay
I have had a similar problem with my 31 for 7 0r 8 years. About once every three or four outings it takes a second push to get anything from the starter button. Just dead, no reaction at all. Sometimes it takes a third press on the button and I think once a fourth.
I have read several theories on the problem but since it has never caused a problem I have stayed lazy. I sure hope your solution works well. That will get me moving.
John Van Dinther
Watermark
PSC 31 #28
wmjr is offline
post #4 of 5 Old 07-12-2012
teejayevans's Avatar
Re: Starter Relay
John Van Dinther
Watermark
PSC 31 #28
Ditto, and I have the second relay that's wired to the starter relay, although it's taken 2, I never remember 4. I figured is was a stuck relay not fully engaging. I since I have 2 relays, it could be either one.
Tom
PS31#111 Cielo Azul
teejayevans is offline
post #5 of 5 Old 07-12-2012
Re: Starter Relay
Had same problem on my Yanmar 3GM about 6-7 years ago.
Seems that voltage is lost on wiring harness. (to many connections)
Installed small, most basic auto relay.(inexpensive) Did the trick, have not had problem since.
Have told many Yanmar owners...also hear problem with some other
brands.
There is extensive info on some old sailnet threads.
Best,
Hugo
HUGOSALT is offline
Looking for a 12V DC under voltage relay stuartbell Gear & Maintenance 6 06-25-2008 01:45 PM
Selector switch or Automatic Relay PBzeer Gear & Maintenance 17 09-04-2007 08:25 AM
GALICIA.. MAYDAY RELAY.. Albatros CMF Boat Review and Purchase Forum 18 01-10-2003 07:45 PM
GALICIA.. MAYDAY RELAY.. Albatros CMF Gear & Maintenance 0 11-30-2002 02:56 AM
GALICIA.. MAYDAY RELAY.. Albatros CMF General Discussion (sailing related) 0 11-30-2002 02:53 AM
HTML code is Off
