07-20-2012
Re: Crealock 37 performance
Originally Posted by sailak
Howdy,
How close does the Crealock sail to the wind? How does she do in light winds? I'm not worried about winning races but don't want to be blown onto the rocks because the boat is a pig.
How does she sail?
Dear Dale, The Crealock 37 is definitely not a "pig" but close-hauled angles of 50 degrees off the wind are not uncommon. As a sometime racing sailor I often find tacking greater than 90 degrees leaves me frustrated. At such times I have to remind myself of why I got this particular boat. So, ....
In your second post you note you want to do more cruising and hence are thinking of the Crealock 37. Perhaps "cruising" is too broad a term which could apply to sailing exclusively with Chesapeake Bay or across the Atlantic. The Crealock 37, Gentleman Bill, was designed for offshore passages and more importantly to get the crew from one place to another in safety and (relative) comfort. The idea being that if you are sailing shorthanded as most cruisers are you don't want to go fast and get all beat up. Instead you want to get there, have a nap, and then be ready to go out to explore your new destination!
At this the Crealock 37 excels. The deck is a wonderfully stable platform on which to work, not a go-fast twitching thing just waiting to chuck you into the drink. So for that stability, and dependable performance we put up with 100 degree tacks -- and try not to go to windward!
Hope this helps
Jay, PSC 37 # 171, Kenlanu
Buck's Harbor, Maine
