fuel filler O-ring - SailNet Community
post #1 of 8 Old 08-25-2012 Thread Starter
fuel filler O-ring
Does anyone know the part number for the o-ring for the fuel filler bronze cap? I have a 31 but assume they are all the same.
JV
Pacific Seacraft 31
wmjr is offline
post #2 of 8 Old 08-26-2012
arisatx's Avatar
Re: fuel filler O-ring
JV:
Why don't you take the current one to the local shipyard, they can find you an equivalent size, probably at the fraction of the cost of a replacement from the fuel cap manufacturer.
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #3 of 8 Old 08-26-2012
Send a message via Yahoo to dacap06
These things are awfully common but come in several sizes. Take the O-ring down to any local marine store that has a good parts inventory and you'll probably find a replacement.
Having a good O-ring on the fuel cap that is doing its job is critical. It keeps water out of your fuel when it rains. Guaranteed -- if water contaminates your fuel you'll have bad fuel in short order because it enables the bugs to grow.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #4 of 8 Old 08-26-2012 Thread Starter
Thanks, yep. Looks like West Marines two Perkins O rings for $8.00. I was hoping to get 10 or 15 on the web for that price
but without a number that will not work.
JV
wmjr is offline
post #5 of 8 Old 08-26-2012
Many hardware stores have great selections of O-rings. I would be surprised if you couldn't find it at your local Ace.
johnharch is offline
post #6 of 8 Old 08-26-2012
John is right . . . beat me to it . . .
mikel1 is offline
post #7 of 8 Old 08-27-2012
BluesHarp's Avatar
I replaced the O-Ring in the diesel fill plate on the deck with a Perco # 0513DP3 1 1/2 inch.
BluesHarp is offline
post #8 of 8 Old 08-28-2012 Thread Starter
Johnharch and BluesHarp (honorable mention to Mike/1,
Thanks. Ace sounds like a good possibility (even if it makes me feel dumb for thinking everything has to be marine store specialty items) I will also check out the Perco.
Appreciate it,
JV
wmjr is offline
mast track filler?!?!?! blt2ski Gear & Maintenance 16 04-18-2010 02:13 PM
Wood rot and filler weephee General Discussion (sailing related) 5 07-08-2009 07:06 PM
Using filler in epoxy saurav16 Gear & Maintenance 10 09-25-2007 01:34 PM
Fuel Filler Hose Replacement rheaton Gear & Maintenance 9 09-19-2007 07:12 AM
Replacement cap for the diesel fuel filler inlet? jackdash Gear & Maintenance 1 06-14-2006 11:13 PM
HTML code is Off
