Zinc for PSC 37 - SailNet Community
post #1 of 5 Old 08-26-2012 Thread Starter
Crealock 37
sailak's Avatar
Dock
Zinc for PSC 37
At the survey the prop and rudder zincs were shot. The owner had picked up some zincs to change them but didn't have the right sizes and doesn't seem to know the size needed. (!?)
It's a 1995 PSC 37, 3-blade fixed pitch prop.
Tear drop shaped zinc on lower rudder hinge.
It's the prop zinc I'm most anxious to get. If this sale goes through I need to get the zincs changed pronto...almost end of season here.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #2 of 5 Old 08-26-2012
Redwood Coast, CA.
fishtrip's Avatar
Re: Zinc for PSC 37
Hi Dale,
Assuming 1" shaft I use a CMC03Z (limited access shaft anode).
For the gudgeon a CMT-20 (teardrop).
David Schachter
Cloud Messenger
1994 PSC 37 #293
San Francisco
fishtrip is offline
post #3 of 5 Old 08-26-2012 Thread Starter
Crealock 37
sailak's Avatar
Dock
Re: Zinc for PSC 37
Ah, so you put the anode ahead of the prop. On this boat it's mounted on the prop hub. From looking at the survey photos I think I have plenty of room ahead of the prop for a donut style zinc.
Thanks
Dale
S/V Elnora
sailak is offline
post #4 of 5 Old 08-28-2012
I don't discuss my member
Fstbttms's Avatar
Re: Zinc for PSC 37
If you want to install a prop zinc, you need a "C" size.
Fstbttms is offline
post #5 of 5 Old 08-28-2012 Thread Starter
Crealock 37
sailak's Avatar
Dock
Re: Zinc for PSC 37
I think the owner had a C at the survey but we weren't able to get it on due to the rudder being so close to the prop --- just couldn't quite get it over the fitting.
Dale
S/V Elnora
sailak is offline
Too much zinc? L124C Gear & Maintenance 24 08-23-2012 08:23 PM
How much zinc is enough? Petar Gear & Maintenance 36 10-17-2011 09:22 PM
Other uses for zinc Bene505 Gear & Maintenance 17 02-07-2009 04:22 PM
HTML code is Off
