Nautical term - SailNet Community
post #1 of 10 Old 09-04-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Nautical term
What is the opening on the bow that you feed your bowlines called?
brokesailor is offline
post #2 of 10 Old 09-04-2012
Re: Nautical term
Broke, I call them Bow Chocks.
Now, I have a question for you. Where do you keep your boat in the Solomons? I ask, because my brother has just been stationed there..and I'm considering moving my boat there for a season. Any suggestions, recommendations? Do folks leave their boats in all winter there?
tempest is online now
post #3 of 10 Old 09-04-2012
SecondWindNC's Avatar
Re: Nautical term
Hawsepipe.
A bow chock serves essentially the same purpose but is usually open at the top and mounted on top of the caprail or gunwale rather than passing through the gunwale like the one pictured in the original post.
A chock would be more along these lines:
Who is staring at the sea is already sailing a little.
SecondWindNC is offline
post #4 of 10 Old 09-04-2012 Thread Starter
SV Skalliwag #141
Nautical term
Tempest: Skalliwag is at Zahnisers. Yes a lot of boats stay at the slip year round but I always put her to bed on the hard.
post #5 of 10 Old 09-04-2012
Re: Nautical term
Originally Posted by SecondWindNC View Post
Hawsepipe.
ok...I thought a Hawes Pipe was typically the opening that the anchor rode passed through.
Hawes Pipe
But I do see, the distinction that you are pointing out.
post #6 of 10 Old 09-04-2012
FSMike's Avatar
Re: Nautical term
Had me scared for a minute, thought I was going to find out after all these years it was spelled hawes pipe. Fortunately, after reading your link, was reassured it is hawse pipe.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #7 of 10 Old 09-05-2012 Thread Starter
SV Skalliwag #141
Re: Nautical term
I looked it up, looks like it should be a hawsehole. The Hawsepipe looks like it would be the opening that the anchor chain feeds into the anchor locker.
post #8 of 10 Old 09-17-2012
Re: Nautical term
After looking at these terms a little more, I believe I was incorrect. Hawsepipe is the opening into the anchor locker, as you said. Chock would accurately describe the "guide" piece for the mooring lines, whether it's a hole through the gunwale or a fitting on top of the gunwale.
post #9 of 10 Old 09-17-2012
Send a message via Yahoo to dacap06
Re: Nautical term
Yes, it is a chock.
A hawsepipe carries the hawser, a chain or cable used for anchoring or towing.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #10 of 10 Old 09-19-2012
S/V Argo-Pacific Seacraft
SVArgo's Avatar
Re: Nautical term
This does vary somewhat between yachting, commercial, and naval marine practice, but that said:
Chock - The "hole" that mooring lines pass through. They can be mounted on the deck/rail, or integral into the bulwark/rail. If they are closed, they are called, well, closed chocks. If you can drop the line down into them, they are open chocks. On larger vessels, if there is a chock at the bow on centerline, it's usually called the "bullnose." Double chocks are oversized for passing multiple lines, particularly for Panama Canal, but that term is really for larger commercial vessels, not yachts.
Hawsepipe - It's what the anchor shank and chain/rode ride in from the windlass. Motor yachts often have an "anchor pocket" for the anchor to ship up tight against, sometimes called the "anchor bolster." Where the chain penetrates the deck after being stripped off the wildcat is the "chain bolster" or "chain pipe," which may be fitted with a "bellmouth" to keep it from fouling.
Then there's all the buttons, bitts, double bitts, timberheads, cleats, open cleats, kevels, and more, but that's another story.
Ryan Roberts
S/V ARGO - Pacific Seacraft 37 Hull No. 309
SVArgo is offline
Loan Term Slayer Boat Review and Purchase Forum 5 09-02-2008 05:03 PM
Nautical term for the "ringband" on the end of the bowsprit? GBurton Sailboat Design and Construction 6 11-04-2007 09:54 PM
question on term sailor_ben General Discussion (sailing related) 3 06-29-2005 08:36 AM
Long term crew CaptainNeil Crew Wanted/Available 0 02-28-2003 06:43 AM
long term cruising gulfstar43 Cruising & Liveaboard Forum 2 12-19-2002 05:01 AM
HTML code is Off
