PSC 37 How many have done away with staysail? - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 09-15-2012
bill norrie
Re: PSC 37 How many have done away with staysail?
SV Terrwyn loves her Stay sails ( we have a working and a storm stay sail ,both hank on ).We crossed the Pacific last year and flew one or the other 24/7.
PSC 37 mast position is 4.14 and therefore a true cutter. Our furling 115% jib comes though on tacking easily with Stay sail backed to create a slot, CLASSIC BEAUTY.
SMOOTH SEAS,
Bill
BillNorrie is offline
post #12 of 16 Old 09-16-2012
SV Skalliwag #141
brokesailor's Avatar
Bill: Do you run the staysil sheet on the cabin top track or on the track on deck inboard of the rigging? If you use the cabin top blocks how many winches do you have on the port side under the dodger? I have one winch (jib halyard winch) but it does not a fairlead to the port side cabin top block.
brokesailor is offline
post #13 of 16 Old 09-16-2012
Crazy Fish is rigged with a roller furling on gib and a detachable stay for the staysail.
Preferred sails for areas with higher range of winds is a yankee on the furler and the staysail. Lots of options to reduce sail and keep the boat balanced. In areas where I will be doing a lot of tacking (ie San Diego Bay), the staysail stay is released and brought back on deck to a small block and tackle to hold it tight, so it does not interfere with the tacking the foresail.
In areas of light winds like San Diego having something larger then an yankee on the forestay is useful. For daysails the staysail is rarely used.
I have no plans to remove the staysail stay from the boat or convert it to roller furling.
Marc Hall
Crazy Fish, Crealock 37 Hull 207
MarcHall is offline
post #14 of 16 Old 09-18-2012
bill norrie
HI Again
on Terrwyn we only have a single winch on port cabin top BUT we also have a " hockey puck" turning fair lead that directs all three lines to the winch.( all three have proximal stoppers also.
We also only use the stay sail sheet fair lead on the cabin top .
Terrwyn is hull no. 239 I believe , 1990
post #15 of 16 Old 10-05-2012
Kenlanu also loves her staysail in combination with the Yankee. Sheet the staysail on the coach roof and it adds 1/2 to 1 knot in light or moderate air respectively; great with reefed main up to "oh crap" time. No problem tacking and we do both one or two day off shore hops and baysailing.
This may not help your negotiations but may help your pleasure with a Great Boat!
Jay
PSC 37 # 171, Kenlanu, currently on the hard getting some TLC in Oriental NC on the way to the Bahamas.
BirdBrain333 is offline
post #16 of 16 Old 10-05-2012
I have a 31 but the arguments for/against staysails are the same: it all depends on what kind of sailing you do. Offshore, I wouldn't feel comfortable with a sloop rig and a big genoa, because in strong wind a partially furled headsail has a very high center of effort and causes unpleasant heel and poor balance just when you don't want it (sail balance is particularly important when using a windvane self-steerer or an underpowered autopilot (like mine)). But in the Chesapeake Bay I remove the inner forestay and use my genny. I have to admit I, too, have sailed around the Bay with 2 headsails just because they look so...nautical!
Sailak, it looks like you are based in Alaska. I'm not familiar with that area but suspect you get some pretty good winds up there. If that's the case, I think having a staysail would be a really nice thing.
Good luck with your new Pacific Seacraft!
Paul Cooper
PSC31 #9 "Wayfarer"
Chesapeake
The secret to sailing is good judgment. Good judgment comes from experience. Experience comes from bad judgment.
okapi3 is offline
Staysail measurements for a 37 WelcomeIII Pacific Seacraft 3 12-03-2014 01:01 AM
Psc31 hank on staysail and storm staysail Summit_Elan Pacific Seacraft 1 09-04-2012 05:34 PM
Staysail rigging terryjoe Sailboat Design and Construction 10 12-13-2010 05:44 PM
Staysail (staysail) on a Freedom 33 freedom33 Introduce Yourself 0 03-06-2010 08:36 PM
Boomed Staysail tdw Gear & Maintenance 33 04-04-2008 02:23 PM
HTML code is Off
